I’ve been exploring MQTT communication with ESP32 using ESP-IDF, particularly for IoT projects that send sensor readings to a dashboard and receive commands from a remote application.
One thing I like about MQTT is its publish/subscribe model. The ESP32 publishes data to a topic, and multiple applications can receive it through a broker without the device needing to know who the subscribers are.
However, things get more interesting when the Wi-Fi connection drops or the broker becomes temporarily unavailable.
For example, if an ESP32 publishes temperature readings every few seconds, should it keep only the latest reading during a disconnection, or store readings in a queue and send them after reconnecting? The right approach depends on whether the data is used for real-time monitoring or needs to be preserved for later analysis.
There are a few other aspects I’m curious about:
How do you handle repeated QoS 1 messages to prevent the same command from being executed twice?
Do you use retained messages for device status, and how do you avoid relying on outdated values?
What’s your approach to reconnect delays when several ESP32 devices might reconnect simultaneously?
For production projects, how do you manage TLS certificate verification and device credentials while keeping memory usage under control?
I recently came across a technical guide from PCBCool, Building Reliable MQTT Communication on ESP32 with ESP-IDF, which discusses topics such as QoS, reconnect handling, message buffering, and secure MQTT connections. It gave me a few more things to consider when designing an MQTT-based application.
For those who have worked with ESP32 and MQTT in real projects, what has been the most challenging communication issue you’ve encountered? I’m particularly interested in approaches that have worked reliably during long-running tests and intermittent network outages.
