# Pironman board power problem
**URL:** <https://forum.sunfounder.com/t/pironman-board-power-problem/472>\
**Category:** General Discussion\
**Created:** [August 19, 2023, 1:46pm UTC](https://forum.sunfounder.com/t/pironman-board-power-problem/472 "2023-08-19T13:46:54Z")\
**Posts on this page:** 1\
**Showing post:** 5
<div class="post-metadata">
**Author:** ![SunFounder\_Moderator](https://avatars.discourse-cdn.com/v4/letter/s/34f0e0/32.png) [@SunFounder\_Moderator](https://forum.sunfounder.com/u/SunFounder_Moderator)\
**Post date:** [November 14, 2023, 9:02am UTC](https://forum.sunfounder.com/t/pironman-board-power-problem/472/5 "2023-11-14T09:02:27Z")
</div>
Already replied to your question on this thread, check it out.
> [@Pironman v2 case ssd stop at random time](https://forum.sunfounder.com/t/pironman-v2-case-ssd-stop-at-random-time/647/3):
> You use a Type-C cable instead of a USB bridge to connect the SSD, after startup, check the working status whether the crash problem still occurs. If you have a multimeter, after you start the Pironman, measure the output voltage of 5V and GND of GPIO. I hope you can provide us with a video of the problem so that we can analyze and solve the problem. If the problem is caused by hardware, we will arrange to send you the corresponding hardware module.
_[View the full topic](https://forum.sunfounder.com/t/pironman-board-power-problem/472)._
