# Several Issues with PiDog "v1"
**URL:** <https://forum.sunfounder.com/t/several-issues-with-pidog-v1/3624>\
**Category:** Robotic kit for Raspberry Pi\
**Created:** [August 4, 2025, 6:53am UTC](https://forum.sunfounder.com/t/several-issues-with-pidog-v1/3624 "2025-08-04T06:53:26Z")\
**Posts on this page:** 1\
**Showing post:** 2
<div class="post-metadata">
**Author:** ![shanbady](https://yyz1.discourse-cdn.com/flex029/user_avatar/forum.sunfounder.com/shanbady/32/1697_2.png) [@shanbady](https://forum.sunfounder.com/u/shanbady)\
**Post date:** [August 4, 2025, 11:55pm UTC](https://forum.sunfounder.com/t/several-issues-with-pidog-v1/3624/2 "2025-08-04T23:55:18Z")
</div>
There are several solutions to the head shaking posted here: [PiDog Servos shaking - #15 by DarrenL](https://forum.sunfounder.com/t/pidog-servos-shaking/1430/15)
Personally I found a rubber band does just fine as shown here: [PiDog Servos shaking - #12 by shanbady](https://forum.sunfounder.com/t/pidog-servos-shaking/1430/12)
The sound issue may be just due to having the wrong default output set on your pi. Install alsa utils via “ **sudo apt-get install alsa-utils”** and then see what the default output is “aplay -L”. you can search online on how to change that to the use the correct output device. you can test it works with “aplay ”
_[View the full topic](https://forum.sunfounder.com/t/several-issues-with-pidog-v1/3624)._
