Sunfounder Agent - apparently does not work with a Pi?
I love that you can copy code from the web lessons - it really helps with installing libraries and for creating my own documentation for the code, BUT It doesn’t seem like the [Run] button should be on them as it is appears you can’t install the Sunfounder Agent on a Raspberry Pi?? It never tells you that anywhere - > I found something here on the forum from July 2024 where the response was that it doesn’t work with the Pis.
It would be super slick if it did work with the Pi. Hint Hint.
Thank you for bringing this to our attention. The SunFounder Create Agent is no longer being updated, and we will update the tutorial pages to remove references to it as soon as possible.
However, the ability to copy code and commands is still available through other tools and dependencies, and we will keep that functionality.
We appreciate your feedback.
