Trying to do the Auto Plant Watering, connected everything
when I go into Arduino IDE and load the code and try to debug, I get lots of errors, 1, it cannot find the ESP8266 libraries, it also cannot find anything on Blynk. I thought that this code was tested???
Hi Marlin,
Regarding the errors you see after loading the auto plant watering code in Arduino IDE, including messages that ESP8266 and Blynk cannot be found, please refer to our official tutorial page and follow the instructions there to download and install the ESP8266 and Blynk related libraries:
This page is part of the Blynk Start chapter. Please complete the following steps in order and your Blynk setup will be ready:
Add libraries: install the ESP8266 and Blynk related libraries in Arduino IDE as described on the page;
Configure Blynk: sign up / log in to your Blynk account, create a Template and a Device, and get the Auth Token, Template ID and Template Name;
Open the example code and fill in the credentials above plus your WiFi SSID and password;
Compile and upload to your board;
Test: open the Serial Monitor to check the connection log, and add widgets in the Blynk App to verify that data and the switch work properly.
If you still get errors, please send us the complete error text (or a screenshot) so we can look into it further.
