Hi there,
I would like to use the pid_fan.py stuff! Is there an alternative main.py - file, that i can download?
This code is still being tested and has not been officially uploaded. It will be updated later and the pid control option will be added.
Now you can directly run this pid_fan.py to see the effect first. There is expect=40 in the code is the expected temperature, you can modify this to keep the CPU temperature at 40 degrees.
