Hi everyone,
I just bought the SunFounder AI Lab Kit, and my Raspberry Pi 5 is currently installed in a Pironman 5 Pro Max. I’d like to use the Fusion HAT+ without taking the Pi out of the case, and I have a few questions before I plug anything in:
Mounting: since the Pi’s GPIO header inside the case is taken by the Pironman’s GPIO expansion board, I plan to connect the Fusion HAT+ to the external GPIO header, ideally with a 40-pin ribbon cable. Is that a supported setup?
HAT EEPROMs: both the Pironman 5 Pro Max (on its GPIO board, as far as I understand) and the Fusion HAT+ have an ID EEPROM on ID_SD/ID_SC. Are the ID pins passed through to the external header? If so, will having two EEPROMs on the same bus cause detection problems, and should I disable one of them or configure anything manually in config.txt?
Power: the Fusion HAT+ can power the Pi through the GPIO 5V pins, while the Pi is already powered through the Pironman’s USB-C. Is it safe to have both connected at the same time, or should I power only one of them? What’s the recommended way to power the servos/motors in this setup?
Pin conflicts: the Pironman uses I2C (OLED) and SPI (RGB LEDs), and the Fusion HAT+ uses I2C, I2S (GPIO 18–21) and its own WS2812 port. Can the Pironman software and the Fusion HAT+ library run at the same time without conflicts?
Thanks a lot for your help (and sorry about the pretty long post…)
In practice, yes — you can use the Fusion HAT+ with the Pi still in the Pironman 5 Pro Max. It is not a configuration we have officially validated though, so here are the details for each of your points.
Mounting
The case’s external headers are a passive breakout for accessories, and a 40-pin ribbon to a HAT is not something we have tested. If you go this route, keep the ribbon short and support the HAT mechanically so the cable and connectors are not under load.
HAT EEPROMs
You are right that both boards carry an ID EEPROM at 0x50, and that collision is real — we ran into it ourselves earlier this year. Since then neither software reads the ID EEPROM: the Fusion HAT+ installer writes dtoverlay=sunfounder-fusionhat into config.txt, and the current Pironman 5 installer asks for your model and writes the matching overlay and variant file. So you do not need to disable either EEPROM or edit config.txt — just make sure both packages are up to date (on an older image, run the Fusion HAT installer once). Avoid EEPROM flashing tools on this stack.
Power
The Fusion HAT+ powers the Pi through the 5V pins and has anti-backflow protection on its side, so the Pi’s supply cannot damage the HAT. We cannot confirm the Pi has reverse protection on its 5V rail, so do not feed it from two sources: when the HAT is on, unplug the case’s USB-C and let the HAT power the Pi, charging it through its own USB-C port. Servos use the shared 5V/5A rail (use an external BEC above 5A); motors run directly from the battery at 6-8.4V, 1.8A per channel.
Pins
No hard conflict. The HAT’s MCU is on I2C 0x17 and the OLED on 0x3C; the case does not use I2S (GPIO18-21); the IR, RGB and fan pins are jumper-selectable. The one to watch is GPIO10 — the case’s RGB LEDs and the HAT’s WS2812/SPI port share MOSI, so use one at a time, or remove the RGB jumper. Also uninstall RPi.GPIO as our docs require.
If anything misbehaves, send us the output of fusion_hat doctor and we will take a look.
