A while ago I bought 3 Galaxy RVR rovers. I have been able to troubleshoot and setup 2 of them to work perfectly, connect to wifi, etc. No matter what I do (which I will list the steps I’ve taken to troubleshoot below) the Galaxy RVR does not broadcast a wifi signal.
Steps I have taken:
Attempted to update the UNO R3 Firmware using the steps here ( Update Firmware — SunFounder GalaxyRVR Kit for Arduino 1.0 documentation ) The port never shows, which I had the same problem with the other 2 rovers so I ended up using the GalaxyRVR code from the GitHub repository (galaxy-rvr/galaxyrvr.ino file https://github.com/sunfounder/galaxy-rvr/archive/refs/heads/main.zip) to upload the update. At this point with the first 2 rovers I was able to continue on to update the ESP32 Cam Firmware and the wifi works successfully (although the camera for all 3 rovers never appears).
With the 3rd rover, the UNO R3 Firmware successfully uploads, but the Wifi does not appear on any devices and I cannot move on to update the ESP32 Cam. Serial monitor output:
GalaxyRVR version 2.0.0Initialzing...SET+RESET...SET+RESET...[Init][OK] 1.4.0[OK]ESP32 firmware version 1.4.0checkFirmwareVersion: 1.4.0SET+NAMEGalaxyRVR...[OK][OK]SET+TYPEGalaxyRVR...[OK][OK]SET+SSIDGalaxyRVR...[OK][OK]SET+PSK12345678...[OK][OK]SET+MODE2...[OK][OK]SET+PORT30102...[OK][OK]SET+START...[OK] 192.168.4.1[OK]Legacy ESP32-CAM: AP up, settings page on http://192.168.4.1Okie!State changed to IDLE[CAM_I] camera stream start on: http://192.168.4.1:9000/mjpg
Please let me know if there are any other troubleshooting steps I can take or if I should order a new ESP32 Cam. Thanks
