Good evening, my name is Giulio, and I’ve encountered a problem with the PiCar X calibration.
If I run the command sudo python3 1.cali_servo_motor.py i had this problem
pin = self.pins[info]
KeyError: PinInfo(number=18, name=‘GPIO24’, names=frozenset({‘24’, ‘BCM24’, ‘J8:18’, ‘WPI5’, ‘GPIO24’, 24, ‘BOARD18’}), pull=‘’, row=9, col=2, interfaces=frozenset({‘’, ‘spi’, ‘dpi’, ‘jtag’, ‘sdio’, ‘gpio’}))
File “/home/robottino/picar-x/example/1.cali_servo_motor.py”, line 20, in
px = Picarx()
File “/usr/local/lib/python3.11/dist-packages/picarx/picarx.py”, line 65, in init
self.right_rear_dir_pin = Pin(motor_pins[1])
File “/usr/local/lib/python3.11/dist-packages/robot_hat/pin.py”, line 96, in init
File “/usr/local/lib/python3.11/dist-packages/robot_hat/pin.py”, line 134, in setup
self.gpio = OutputDevice(self._pin_num)
File “/usr/lib/python3/dist-packages/gpiozero/devices.py”, line 108, in call
self = super().call(*args, **kwargs)
File “/usr/lib/python3/dist-packages/gpiozero/output_devices.py”, line 74, in init
super().init(pin, pin_factory=pin_factory)
File “/usr/lib/python3/dist-packages/gpiozero/mixins.py”, line 75, in init
super().init(*args, **kwargs)
File “/usr/lib/python3/dist-packages/gpiozero/devices.py”, line 553, in init
File “/usr/lib/python3/dist-packages/gpiozero/pins/pi.py”, line 413, in pin
File “/usr/lib/python3/dist-packages/gpiozero/pins/lgpio.py”, line 126, in init
lgpio.gpio_claim_input(
raise error(error_text(v))
lgpio.error: ‘GPIO busy’
how can I fix it?
thanks
