The clear plastic part for the front of the case arrived broken. I could glue it back together but I would rather have one that was whole to begin with. Is it possible to have one shipped to me?
I’m so sad for you. You can contact consumers service at service@sunfounder.com , it could help if you add some pictures of broken part and if package got hurt during shipping. Unfortunately sunfounder are closed for holiday until October 8th.
OK. Thanks.
One other thing. How do I turn the OLED display on and off?
The command ‘pironman5 -al’ doesn’t work.
Actually, there’s no option to turn on\off OLED display nor to set the brightness. I’m not sure but I think sunfounder are working on it.
Maybe if you disable i2c or disconnect OLED display.
Jcisn, regarding the damage to your received pironman5, please provide images of any damaged parts, and we will send you new module as replacements.
As for turning the OLED display on and off, the current version of the pironman5 software you are using does not support this feature. We have added the functionality to control the OLED screen in the next software update for pironman5, which is expected to be released soon.
Thank you for your patience.
Ok… Here’s the photo.
My address is.
Jose Cisneros
`1110 Washington Ave, Muskegon, MI. 49441
Regards,
Jose
Here’s the tracking link of the acrylic board:
It should be showed within 3 days.
Hi, how to apply the new software? Is it de-install and install the new software or how can I update the new version. Where to get it?
Thank you!
For now they are working on the new version. When they release it you’ll need to follow the same instructions:
In the install procedure it remove old version.
We just need to be patient ![]()
