I’ve recently bought the Fusion Hat and am trying to use it with my Raspberry Pi 3.
I’ve tried installing under Raspian Bullseye (Debian 11) and Raspian Bookworm (Debian 12) and keep getting the following errors in the install log and the installation script shows failure for compiling the driver:
✗ Compile driver
Building Fusion Hat driver and device tree overlay…
make -C /lib/modules/5.10.103-v7+/build M=/home/pi/fusion-hat/driver modules
make[1]: Entering directory ‘/usr/src/linux-headers-5.10.103-v7+’
CC [M] /home/pi/fusion-hat/driver/i2c.o
CC [M] /home/pi/fusion-hat/driver/adc.o
CC [M] /home/pi/fusion-hat/driver/battery.o
/home/pi/fusion-hat/driver/battery.c: In function ‘fusion_hat_battery_init’:
/home/pi/fusion-hat/driver/battery.c:192:5: warning: ISO C90 forbids mixed decl>
192 | struct power_supply_config psy_cfg = {};
CC [M] /home/pi/fusion-hat/driver/shutdown.o
CC [M] /home/pi/fusion-hat/driver/pwm.o
/home/pi/fusion-hat/driver/pwm.c: In function ‘period_store’:
/home/pi/fusion-hat/driver/pwm.c:155:3: warning: ISO C90 forbids mixed declarat>
155 | uint32_t frequency = 1000000 / period;
/home/pi/fusion-hat/driver/pwm.c: In function ‘fusion_hat_pwm_probe’:
/home/pi/fusion-hat/driver/pwm.c:374:55: warning: passing argument 2 of ‘kobjec>
374 | ret = kobject_init_and_add(&pwm_channels[i].kobj, &pwm_channel_ktyp>
In file included from ./include/linux/energy_model.h:7,
from ./include/linux/device.h:16,
from /home/pi/fusion-hat/driver/main.h:12,
from /home/pi/fusion-hat/driver/pwm.c:10:
./include/linux/kobject.h:99:44: note: expected ‘struct kobj_type *’ but argume>
99 | struct kobj_type *ktype, struct kobject *paren>
CC [M] /home/pi/fusion-hat/driver/button.o
/home/pi/fusion-hat/driver/button.c: In function ‘fusion_hat_button_poll_work’:
/home/pi/fusion-hat/driver/button.c:35:5: warning: ISO C90 forbids mixed declar>
35 | int ret = fusion_hat_i2c_read_byte(dev->client, CMD_READ_BUTTON_STA>
/home/pi/fusion-hat/driver/button.c:45:5: warning: ISO C90 forbids mixed declar>
45 | bool current_state = (button_status & 0x01);
CC [M] /home/pi/fusion-hat/driver/led.o
CC [M] /home/pi/fusion-hat/driver/speaker.o
CC [M] /home/pi/fusion-hat/driver/main.o
/home/pi/fusion-hat/driver/main.c: In function ‘fusion_hat_probe’:
/home/pi/fusion-hat/driver/main.c:178:53: error: macro “class_create” requires >
178 | fusion_dev->class = class_create(FUSION_HAT_NAME);
In file included from ./include/linux/device.h:31,
from ./include/linux/acpi.h:15,
from ./include/linux/i2c.h:13,
from /home/pi/fusion-hat/driver/main.c:2:
./include/linux/device/class.h:259: note: macro “class_create” defined here
259 | #define class_create(owner, name)
/home/pi/fusion-hat/driver/main.c:178:25: error: ‘class_create’ undeclared (fir>
| vfs_create
/home/pi/fusion-hat/driver/main.c:178:25: note: each undeclared identifier is r>
/home/pi/fusion-hat/driver/main.c: At top level:
/home/pi/fusion-hat/driver/main.c:338:14: error: initialization of ‘int ()(str>
338 | .probe = fusion_hat_probe,
/home/pi/fusion-hat/driver/main.c:338:14: note: (near initialization for ‘fusio>
/home/pi/fusion-hat/driver/main.c:339:15: error: initialization of ‘int ()(str>
339 | .remove = fusion_hat_remove,
/home/pi/fusion-hat/driver/main.c:339:15: note: (near initialization for ‘fusio>
cc1: some warnings being treated as errors
make[2]: *** [scripts/Makefile.build:280: /home/pi/fusion-hat/driver/main.o] Er>
make[1]: *** [Makefile:1825: /home/pi/fusion-hat/driver] Error 2
make[1]: Leaving directory ‘/usr/src/linux-headers-5.10.103-v7+’
make: *** [Makefile:43: all] Error 2
✗ Install driver
Installing Fusion Hat driver and device tree overlay…
rmmod fusion_hat || echo "Warning: Failed to unload fusion_hat module. It may b>
rmmod: ERROR: Module fusion_hat is not currently loaded
Warning: Failed to unload fusion_hat module. It may be in use or require additi>
make[1]: Entering directory ‘/home/pi/fusion-hat/driver’
Installing kernel module…
make -C /lib/modules/5.10.103-v7+/build M=/home/pi/fusion-hat/driver modules_in>
make[2]: Entering directory ‘/usr/src/linux-headers-5.10.103-v7+’
cat: /home/pi/fusion-hat/driver/modules.order: No such file or directory
DEPMOD 5.10.103-v7+
Warning: modules_install: missing ‘System.map’ file. Skipping depmod.
make[2]: Leaving directory ‘/usr/src/linux-headers-5.10.103-v7+’
Loading required IIO subsystem module…
Updating module dependencies…
depmod -a
Module installation completed.
I’m not that adept with Linux but am doing the install as per the instructions:
curl -sSL https://raw.githubusercontent.com/sunfounder/sunfounder-installer-scripts/main/install-fusion-hat.sh | sudo bash
Can someone advise how to resolve this please?
Thanks
