I keep getting the same error when trying to install my board. I have recently updated my raspberry pi but other then that i am pretty new to this stuff so any help would be appropriated. here is what i get.(had to change .org to .or and http to htp to post)
/usr/local/lib/python3.7/dist-packages/setuptools/command/install.py:37: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
setuptools.SetuptoolsDeprecationWarning,
/usr/local/lib/python3.7/dist-packages/setuptools/command/easy_install.py:159: EasyInstallDeprecationWarning: easy_install command is deprecated. Use build and pip and other standards-based tools.
EasyInstallDeprecationWarning,
running bdist_egg
running egg_info
writing robot_hat.egg-info/PKG-INFO
writing dependency_links to robot_hat.egg-info/dependency_links.txt
writing entry points to robot_hat.egg-info/entry_points.txt
writing top-level names to robot_hat.egg-info/top_level.txt
reading manifest file ‘robot_hat.egg-info/SOURCES.txt’
adding license file ‘LICENSE’
writing manifest file ‘robot_hat.egg-info/SOURCES.txt’
installing library code to build/bdist.linux-armv7l/egg
running install_lib
running build_py
creating build/bdist.linux-armv7l/egg
creating build/bdist.linux-armv7l/egg/robot_hat
copying build/lib/robot_hat/servo.py → build/bdist.linux-armv7l/egg/robot_hat
copying build/lib/robot_hat/pin.py → build/bdist.linux-armv7l/egg/robot_hat
copying build/lib/robot_hat/i2c.py → build/bdist.linux-armv7l/egg/robot_hat
copying build/lib/robot_hat/tts.py → build/bdist.linux-armv7l/egg/robot_hat
copying build/lib/robot_hat/motor.py → build/bdist.linux-armv7l/egg/robot_hat
copying build/lib/robot_hat/filedb.py → build/bdist.linux-armv7l/egg/robot_hat
copying build/lib/robot_hat/pwm.py → build/bdist.linux-armv7l/egg/robot_hat
copying build/lib/robot_hat/version.py → build/bdist.linux-armv7l/egg/robot_hat
copying build/lib/robot_hat/utils.py → build/bdist.linux-armv7l/egg/robot_hat
copying build/lib/robot_hat/adc.py → build/bdist.linux-armv7l/egg/robot_hat
copying build/lib/robot_hat/modules.py → build/bdist.linux-armv7l/egg/robot_hat
copying build/lib/robot_hat/basic.py → build/bdist.linux-armv7l/egg/robot_hat
copying build/lib/robot_hat/music.py → build/bdist.linux-armv7l/egg/robot_hat
copying build/lib/robot_hat/init.py → build/bdist.linux-armv7l/egg/robot_hat
copying build/lib/robot_hat/robot.py → build/bdist.linux-armv7l/egg/robot_hat
byte-compiling build/bdist.linux-armv7l/egg/robot_hat/servo.py to servo.cpython-37.pyc
byte-compiling build/bdist.linux-armv7l/egg/robot_hat/pin.py to pin.cpython-37.pyc
byte-compiling build/bdist.linux-armv7l/egg/robot_hat/i2c.py to i2c.cpython-37.pyc
byte-compiling build/bdist.linux-armv7l/egg/robot_hat/tts.py to tts.cpython-37.pyc
byte-compiling build/bdist.linux-armv7l/egg/robot_hat/motor.py to motor.cpython-37.pyc
byte-compiling build/bdist.linux-armv7l/egg/robot_hat/filedb.py to filedb.cpython-37.pyc
byte-compiling build/bdist.linux-armv7l/egg/robot_hat/pwm.py to pwm.cpython-37.pyc
byte-compiling build/bdist.linux-armv7l/egg/robot_hat/version.py to version.cpython-37.pyc
byte-compiling build/bdist.linux-armv7l/egg/robot_hat/utils.py to utils.cpython-37.pyc
byte-compiling build/bdist.linux-armv7l/egg/robot_hat/adc.py to adc.cpython-37.pyc
byte-compiling build/bdist.linux-armv7l/egg/robot_hat/modules.py to modules.cpython-37.pyc
byte-compiling build/bdist.linux-armv7l/egg/robot_hat/basic.py to basic.cpython-37.pyc
byte-compiling build/bdist.linux-armv7l/egg/robot_hat/music.py to music.cpython-37.pyc
byte-compiling build/bdist.linux-armv7l/egg/robot_hat/init.py to init.cpython-37.pyc
byte-compiling build/bdist.linux-armv7l/egg/robot_hat/robot.py to robot.cpython-37.pyc
creating build/bdist.linux-armv7l/egg/EGG-INFO
copying robot_hat.egg-info/PKG-INFO → build/bdist.linux-armv7l/egg/EGG-INFO
copying robot_hat.egg-info/SOURCES.txt → build/bdist.linux-armv7l/egg/EGG-INFO
copying robot_hat.egg-info/dependency_links.txt → build/bdist.linux-armv7l/egg/EGG-INFO
copying robot_hat.egg-info/entry_points.txt → build/bdist.linux-armv7l/egg/EGG-INFO
copying robot_hat.egg-info/not-zip-safe → build/bdist.linux-armv7l/egg/EGG-INFO
copying robot_hat.egg-info/top_level.txt → build/bdist.linux-armv7l/egg/EGG-INFO
creating ‘dist/robot_hat-2.2.15-py3.7.egg’ and adding ‘build/bdist.linux-armv7l/egg’ to it
removing ‘build/bdist.linux-armv7l/egg’ (and everything under it)
Processing robot_hat-2.2.15-py3.7.egg
removing ‘/usr/local/lib/python3.7/dist-packages/robot_hat-2.2.15-py3.7.egg’ (and everything under it)
creating /usr/local/lib/python3.7/dist-packages/robot_hat-2.2.15-py3.7.egg
Extracting robot_hat-2.2.15-py3.7.egg to /usr/local/lib/python3.7/dist-packages
robot-hat 2.2.15 is already the active version in easy-install.pth
Installing robot_hat script to /usr/local/bin
Installed /usr/local/lib/python3.7/dist-packages/robot_hat-2.2.15-py3.7.egg
Processing dependencies for robot-hat==2.2.15
Finished processing dependencies for robot-hat==2.2.15
Install dependencies with apt-get:
- update apt-get… Done
- install raspi-config… Done
- install i2c-tools… Done
- install espeak… Done
- install libsdl2-dev… Done
- install libsdl2-mixer-dev… Done
- install portaudio19-dev… Done
- install pico2wave… Error
Install dependencies with pip3:
pip3 install with --break-system-packages - update pip3… Done
- install smbus2… Done
- install gpiozero… Done
- install pyaudio… Done
- install spidev… Done
- install pyserial… Done
- install pillow… Done
- install ‘pygame>=2.1.2’… Done
Setup interfaces - turn on I2C… Done
- turn on SPI… Done
Copy dtoverlay - copy Servo Hat+ dtoverlay… Error
install pico2wave error:
Status:100
Error:–2024-10-15 20:08:37-- htp://ftp.debian.org/debian/pool/non-free/s/svox/libttspico0_1.0+git20130326-11_armhf.deb
Resolving ftp.debian.or (ftp.debian.or)… 2a04:4e42:600::644, 2a04:4e42:200::644, 2a04:4e42::644, …
Connecting to ftp.debian.or (ftp.debian.or)|2a04:4e42:600::644|:80… connected.
HTTP request sent, awaiting response… 200 OK
Length: 124840 (122K) [application/vnd.debian.binary-package]
Saving to: ‘libttspico0_1.0+git20130326-11_armhf.deb.1’
0K .......... .......... .......... .......... .......... 41% 809K 0s
50K .......... .......... .......... .......... .......... 82% 1.43M 0s
100K … … . 100% 1.07M=0.1s
2024-10-15 20:08:38 (1.03 MB/s) - ‘libttspico0_1.0+git20130326-11_armhf.deb.1’ saved [124840/124840]
–2024-10-15 20:08:38-- htp://ftp.debian.org/debian/pool/non-free/s/svox/libttspico-utils_1.0+git20130326-11_armhf.deb
Resolving ftp.debian.or (ftp.debian.or)… 2a04:4e42::644, 2a04:4e42:200::644, 2a04:4e42:400::644, …
Connecting to ftp.debian.or (ftp.debian.or)|2a04:4e42::644|:80… connected.
Length: 9440 (9.2K) [application/vnd.debian.binary-package]
Saving to: ‘libttspico-utils_1.0+git20130326-11_armhf.deb.1’
0K ......... 100% 916K=0.01s
2024-10-15 20:08:38 (916 KB/s) - ‘libttspico-utils_1.0+git20130326-11_armhf.deb.1’ saved [9440/9440]
Reading package lists…
Building dependency tree…
Reading state information…
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libttspico0 : Depends: libc6 (>= 2.29) but 2.28-10+rpt2+rpi1+deb10u2 is to be installed
E: Unable to correct problems, you have held broken packages.
copy Servo Hat+ dtoverlay error:
Status:1
Error:cp: cannot create regular file ‘/boot/firmware/overlays/’: No such file or directory
