Issue with ultasonic
After a break of a few months I returned to the pidog and reinstalled all software. However now there is an issue with the untrasonic initialising. It just reports -1.0 cm and I get the error message shown below. I have reseated the GPIOs several times.
config_file: /home/drxtal/.config/pidog/pidog.conf
robot_hat init … done
imu_sh3001 init … done
rgb_strip init … done
dual_touch init … done
sound_direction init … done
sound_effect init … pinctrl set 20 op dh
done
ultrasonic init … fail
Process sensory_process:
pin = self.pins\[info\]
KeyError: PinInfo(number=7, name=‘GPIO4’, names=frozenset({‘WPI7’, 4, ‘4’, ‘BOARD7’, ‘BCM4’, ‘J8:7’, ‘GPIO4’}), pull=‘’, row=4, col=1, interfaces=frozenset({‘’, ‘dpi’, ‘uart’, ‘i2c’, ‘spi’, ‘gpio’}))
File “/usr/local/lib/python3.13/dist-packages/pidog/pidog.py”, line 590, in sensory_process_work
trig = Pin('D1')
File “/usr/local/lib/python3.13/dist-packages/robot_hat/pin.py”, line 96, in _init_
File “/usr/local/lib/python3.13/dist-packages/robot_hat/pin.py”, line 134, in setup
self.gpio = OutputDevice(self.\_pin_num)
File “/usr/lib/python3/dist-packages/gpiozero/devices.py”, line 108, in _call_
self = super().\__call_\_(\*args, \*\*kwargs)
File “/usr/lib/python3/dist-packages/gpiozero/output_devices.py”, line 74, in _init_
super().\__init_\_(pin, pin_factory=pin_factory)
File “/usr/lib/python3/dist-packages/gpiozero/mixins.py”, line 75, in _init_
super().\__init_\_(\*args, \*\*kwargs)
File “/usr/lib/python3/dist-packages/gpiozero/devices.py”, line 553, in _init_
File “/usr/lib/python3/dist-packages/gpiozero/pins/pi.py”, line 413, in pin
File “/usr/lib/python3/dist-packages/gpiozero/pins/lgpio.py”, line 126, in _init_
lgpio.gpio_claim_input(
    self.factory.\_handle, self.\_number, lgpio.SET_PULL_NONE)
return \_u2i(\_lgpio.\_gpio_claim_input(handle&0xffff, lFlags, gpio))
raise error(error_text(v))
lgpio.error: ‘GPIO busy’
File “/usr/lib/python3.13/multiprocessing/process.py”, line 313, in _bootstrap
self.run()
File “/usr/lib/python3.13/multiprocessing/process.py”, line 108, in run
self.\_target(\*self.\_args, \*\*self.\_kwargs)
File “/usr/local/lib/python3.13/dist-packages/pidog/pidog.py”, line 597, in sensory_process_work
raise ValueError(e)
ValueError: ‘GPIO busy’
Please check if the wiring of your ultrasonic module is correct.
Refer to the assembly diagram to confirm the ultrasonic sensor connections:
Black → GND
Red → 3.3V
White → Pin 17
Yellow → Pin 4
After confirming the ultrasonic module wiring is correct, it is recommended to restart the system and then run the example code again to see if it works.
Please check if the WiFi network you are connected to is stable. If possible, try switching to a WiFi network with a stronger signal and then run the code example again.
