I have Pi OS LITE , and i have KVM installed and running a VM. It seems like my OLED display that shows the stats shows all the stats for the main pi itself and the VM. How can i change this ???
May I ask which case you are currently using?
Could you please let us know which version of the Pironman 5 software you have installed?
To help us investigate further, would you mind providing the debug log information? You can retrieve it by running this command in your terminal:
Additionally, we highly recommend following the official online tutorial for installing the Pironman 5 software to ensure the process is completed correctly.
25/11/05 21:38:48.352 [INFO]
25/11/05 21:38:48.352 [INFO] ############################################################
25/11/05 21:38:48.352 [DEBUG] Config path: /opt/pironman5/venv/lib/python3.13/site-packages/pironman5/config.json
25/11/05 21:38:48.352 [DEBUG] Pironman5 version: 1.2.21
25/11/05 21:38:48.352 [DEBUG] Variant: Pironman 5
25/11/05 21:38:48.353 [DEBUG] Config: {‘system’: {‘data_interval’: 1, ‘rgb_color’: ‘#0a1aff’, ‘rgb_brightness’: 100, ‘rgb_style’: ‘rainbow’, ‘rgb_speed’: 93, ‘rgb_enable’: True, ‘rgb_led_count’: 4, ‘temperature_unit’: ‘F’, ‘oled_enable’: True, ‘oled_rotation’: 0, ‘oled_disk’: ‘/dev/nvme0n1’, ‘oled_network_interface’: ‘br0’, ‘gpio_fan_pin’: 6, ‘gpio_fan_mode’: 0, ‘debug_level’: ‘INFO’}}
25/11/05 21:38:48.353 [DEBUG] Device info: {‘name’: ‘Pironman 5’, ‘id’: ‘pironman5’, ‘peripherals’: [‘storage’, ‘cpu’, ‘network’, ‘memory’, ‘history’, ‘log’, ‘ws2812’, ‘cpu_temperature’, ‘gpu_temperature’, ‘temperature_unit’, ‘oled’, ‘clear_history’, ‘delete_log_file’, ‘pwm_fan_speed’, ‘gpio_fan_state’, ‘gpio_fan_mode’], ‘version’: ‘1.2.21’, ‘app_name’: ‘pironman5’}
25/11/05 21:38:48.353 [DEBUG] PM_Auto version: 1.2.12
25/11/05 21:38:48.353 [DEBUG] PM_Dashboard version: 1.2.10
25/11/05 21:38:48.556 [INFO] PMAuto started
25/11/05 21:38:48.639 [INFO] PmDashboard started
- pironman 5
- latest version
Based on the pictures you provided, it’s possible that the OLED screen has been damaged due to non-stop operation over a long period, resulting in burnt pixels.
Please contact service@sunfounder.com for further assistance.
