Lesson 8 of Mcwhorter course - it crash!
I am reporting a reproducible system reboot issue when using Piper TTS on a Raspberry Pi 5 with the AI
Fusion HAT software image provided by SunFounder.
The problem does not occur on Raspberry Pi 4 using the corresponding SunFounder image and the same
test code.
The reboot occurs during Piper speech synthesis and can be reproduced even without using the Python
Fusion HAT library.
Hardware Configuration
Raspberry Pi
Model: Raspberry Pi 5
RAM: 4 GB
Power Supply: Official Raspberry Pi 27W USB-C Power Supply
AI Hardware
SunFounder AI Fusion HAT
Peripherals Connected
USB keyboard
USB mouse
Operating System
Official AI Fusion HAT image downloaded from SunFounder website
Kernel: 6.12.93+rpt-rpi
Initial Symptoms
Running SunFounder Piper TTS examples causes the Raspberry Pi 5 to reboot unexpectedly.
Typical behavior:
Program starts normally
Several seconds later
Raspberry Pi suddenly reboots
No error message is shown
No graceful shutdown occurs
Comparison with Raspberry Pi 4
Raspberry Pi 4
Result:
Piper TTS works correctly
Speech is generated and played
No reboot occurs
Raspberry Pi 5
Result:
System reboots during speech generation
This strongly suggests a Raspberry Pi 5 specific compatibility issue.
Journal and Crash Investigation
Persistent journaling was enabled.
Previous boot logs were reviewed using:
journalctl -b -1
journalctl -k -b -1
Findings:
No kernel panic
No OOPS
No Call Trace
No Out Of Memory condition
No PCIe errors
No Fusion HAT driver errors
The journal only reports:
system.journal corrupted or uncleanly shut down
indicating an abrupt system reset.
Fusion HAT Driver Status
Kernel log shows:
fusion_hat: loading out-of-tree module taints kernel
fusion_hat 1-0017: Fusion Hat driver probed successfully
Driver loads successfully.
Python Reproduction
Original SunFounder example:
from fusion_hat.tts import Piper
tts = Piper()
tts.set_model(‘en_US-amy-low’)
msg = “Hi, I’m Piper TTS. Are you ready to rumble? I am here to pump you up!”
tts.say(msg, stream=False)
Result:
Raspberry Pi 5 reboots
Step-by-Step Isolation Test
Test code:
print(“STEP 1”)
print(“STEP 2”)
tts = Piper()
print(“STEP 3”)
print(“STEP 4”)
tts.say(“hello”, stream=False)
print(“STEP 5”)
Observed behavior:
STEP 1 printed
STEP 2 printed
STEP 3 printed
STEP 4 printed
System rebooted before STEP 5
Conclusion:
The reboot occurs inside:
tts.say(…)
or immediately after entering this function.
ONNX Runtime Warning
During Piper initialization:
[W:onnxruntime:Default, device_discovery.cc:211 DiscoverDevicesForPlatform]
GPU device discovery failed:
device_discovery.cc:91 ReadFileContents Failed to open file:
“/sys/class/drm/card1/device/vendor”
This warning does not appear fatal and execution continues afterwards.
Critical Reproduction Without Fusion HAT Python Library
To eliminate the Fusion HAT Python wrapper, Piper was executed directly:
echo “a” | piper
-m /home/pi/.piper_models/en_US-amy-low.onnx
-f /tmp/a.wav
Result:
Raspberry Pi 5 immediately reboots
WAV file is never created
This is the most important finding.
Because the crash occurs when executing Piper directly, the issue does not appear to be caused by:
Thonny
User Python code
fusion_hat.tts wrapper
Audio playback
The reboot occurs during Piper/ONNX p
rocessing itself.
Based on all tests performed:
Eliminated Causes
User Python code
Audio hardware
Voice HAT audio playback
Raspberry Pi power supply
Thermal throttling
Undervoltage
Thonny IDE
ALSA playback path
Most Likely Cause
A compatibility issue between:
Piper
Embedded ONNX Runtime
7
SunFounder AI Fusion HAT software stack
Raspberry Pi 5
The issue is reproducible and appears specific to Raspberry Pi 5.
Minimal Reproduction
echo “a” | piper
-f /tmp/a.wav
Expected result:
WAV file created
Actual result:
No WAV file produced
We have reproduced the issue you described. We found that when a USB mouse and keyboard are connected to the Raspberry Pi 5, running tts_piper.py causes the system to reboot. However, when no USB mouse or keyboard is connected, the issue does not occur.
We have already reported this to our R&D team. They have tested and found that the newer version of Piper TTS has resolved the problem, so we have updated our image file accordingly.
We will finish updating the new image and make it available for download within the next two days. Please wait a couple of days and then re-download the latest image from our website.
We apologize for the inconvenience and thank you for your patience.
Hi!
Someone replied to your post.
| SunFounder_Moderator
June 26 |
You told me five days ago about a new version of the image but till now it doesn’t!
Look the changelog below:
1.0.0 - 2026-05-20- Upgraded fusion-hat library
  • Minor fixes
  • Pre-installed multiple TTS & STT models
0.2.1 - 2026-05-08- Added YOLO object detection model
  • Added OLED driver
  • Added NeoPixel driver
  • Upgraded sunfounder-voice-assistant
  • Upgraded fusion-hat
  • Other fixes
0.1.0 - 2026-04-08- Fixed model permission issue
  • Added YOLO dependencies
  • Updated to latest ai-lab-kit code
0.0.1 - 2026-03-20- First release
When do you release the new version?
We apologize for the delay – the new image is now ready and currently in the final testing phase. If all goes well, it should be available for download by next Monday.
In the meantime, you can manually update the Fusion HAT driver by running the following command in your terminal:
curl -sSL https://raw.githubusercontent.com/sunfounder/fusion-hat/main/install.sh | sudo bash
If you encounter a “Fusion HAT not loaded” error after the update, please run this command to reload the driver:
fusion_hat doctor --fix
We appreciate your understanding!
Hi!
I have used your new version ai.fusion.lab.kit-1.1.0.img but in tts_piper.py code my RP5 crashed again! In RP4 there´s no problem.
Any idea?
Kind regards
We have also not been able to reproduce this issue on our end recently. In the latest image version, we have already fixed the reproducible problems we found. At this point, we can only try to gather more clues from your setup to identify any remaining edge cases.
Could you please share more details about your usage environment?
Are you using any external peripherals such as HDMI monitor, mouse, or keyboard?
What is your power supply setup (e.g., official Pi 5 power supply, third‑party adapter, etc.)?
Have you tested the same SD card on both a Pi 4 and a Pi 5 – and does the crash only happen on the Pi 5?
Are you using the latest image (updated on July 2) available from this link?
:link: AI Fusion Lab Kit - SunFounder Downloads
Do other TTS examples work without crashing?
If other TTS options work, would you be open to using an alternative TTS engine temporarily, while we continue investigating? This would allow you to proceed with your coursework.
Please let us know if you can try any of these steps. We will continue to monitor this case and appreciate your cooperation.
Hi!
sorry for the delay in answering, I was out of home.
Are you using any external peripherals such as an HDMI monitor, mouse, or keyboard?
Only an HDMI monitor but I used VNC.
Official Pi5 power supply.
Yes. I tried the sd card for Pi4 and Pi5 created by Raspberry Pi imager.
Yes, the ai.fusion.lab.kit-1.1.0.img
I haven’t tried. But the lesson 14 Macworter lesson crashed only in Pi5. The Pi4 works fine but a little slow. and the voice sometimes is truncated.
I´m using Pi4 and I´m in lesson 14 but I think that’s not as good as Pi5.
We have also tested Lesson 14 of the McWhorter course, and it runs normally without crashing.
However, we noticed that if the language code is written as “en-US” instead of “en-us” in the code, it will speak once and then crash.
stt = STT("en-us")
Could you please check what error message you are seeing on your side? If possible, you may also send us your code for Lesson 14 so we can test it here.
The problem is not sintax error. I fix it and the problem perists.
There’s no error, it only crash and only in Raspberry pi 5. With Raspberry pi 4 it’s runs fine!
Hi!
Follow attached a video showing the problem.
If you need something more feel fine ask me.
Hugs!
(Attachment 20260722_171908.mp4 is missing)
We have been trying to reproduce your issue, but have not been successful so far. We also noticed that the video attachment you sent is missing – could you please upload it to a cloud service like Google Drive, OneDrive, or Dropbox, and share the link with us? Make sure to grant us access permissions.
We are still working on reproducing your issue and will continue to investigate. Any additional information you can provide will be very helpful.
Please send me a Google account to upload the video
