Pidog tail servo not responsive to alignment command after running the alignment program. How do I know if I have a Pidog v2 which has already-zeroed servos
[quote=“JIM3, post:1, topic:3139, full:true”]
[/quote] Thank you for reaching out. Here are the steps to properly zero your servos and calibrate your PiDog:
- Before Running the Zeroing Script:
- Attach the servo horn to the servo.
- Manually rotate the servo horn to randomize the servo’s initial position.
- Zeroing the Servo:
- Run the zeroing script
servo_zeroing.py. - Connect the servo to the P11 pin—you will observe the servo returning to its zero position.
- Final Installation:
- With the power ON, securely mount the servo to the metal plate.
- Servo Calibration:
- After all servos are zeroed and installed, perform a full servo calibration. This step is critical to ensure PiDog operates stably and efficiently, correcting any imbalances or errors from assembly or structural tolerances.
For visual guidance, please refer to our assembly videos:
