When I took hold of the lens protector the camera cam off in my hand. Was this supposed to happen? It looks like the sticky tape that was designed to stick the camera sensor to the board it came on was never pealed and stuck down. Is this normal? How does the connector for teh camera work or is this now broken?
The PiDog camera module consists of two parts: the camera component (the lens part) and the PCB board. The back of the camera component has adhesive tape, and in normal assembly the component is attached to the PCB and held in place by that adhesive. So when the camera component came off as you took hold of the lens protector, it is usually an assembly issue where the adhesive did not stick properly (or the release liner on the adhesive was not peeled off). It is generally not damage, and you can reattach it yourself.
Here is what we suggest:
Check the adhesive on the back of the camera component and on the corresponding position of the PCB. If the release film (protective liner) is still on the adhesive, please peel it off;
After making sure the ribbon cable is properly connected and the connector latch is intact, align the component with the PCB and press it gently for a few seconds so it sticks firmly;
After reassembly, run a camera example (such as the vilib camera preview) to check that the image is normal.
Please try the steps above first to reattach it. If the camera still does not work properly after that (for example, no image, errors, or the ribbon cable/connector is visibly damaged), just send us photos and we will look into it further. Please take clear photos of the camera component, the PCB, the ribbon cable and the connector from several angles, and check whether the blue marking at the end of the ribbon cable is intact and whether the connector latch is undamaged. Please upload them to Google Drive (or another cloud drive) and send us the link, and set the link permission to “Anyone with the link can view”, otherwise we cannot access them. If the component or the ribbon cable turns out to be damaged, we will have our technical team confirm the solution.
About the sound effect init failure
The speaker is already attached to the HAT, so the connection is generally fine. The common cause is that I2S audio is not enabled or the related libraries are not installed correctly. Please first follow the official FAQ:
cd ~/robot-hat
sudo bash i2samp.sh
Run it several times if there is still no sound.
Also please make sure you have installed the robot-hat, vilib and pidog modules as described in the tutorial:
Please do not run sudo apt install git python3-pip python3-setuptools python3-smbus; just install the libraries above.
To help us locate the issue further, please provide:
Which example script you are running (e.g. 11_sound_direction_read.py or another one);
The complete error text in the terminal (screenshot or copy-paste is fine);
Whether your Raspberry Pi OS is 64-bit or 32-bit;
Whether you have run i2samp.sh and what the result was.
Once we receive this information, we will continue to help you troubleshoot. Thank you for your cooperation, and feel free to contact us anytime.
Camera installed but I get the error no camera number 0 found which I run the command: sudo python3 7_face_track.py command
The camera component is back in place but the camera is still not detected. Please follow these four steps — each one is simple.
Run these two commands first and send us the full output:
ls /dev/video* ; dmesg | grep -i -E “camera|unicam|imx|ov”
rpicam-hello --list-cameras
If /dev/video0 is listed and rpicam-hello lists a camera, the hardware is fine and the issue is in software — we will keep investigating.
If you get “no such file” and “no cameras available”, the system does not see the camera at all. Please go to step 2.
Re-seat the ribbon cable following the official assembly video (both ends):
Key points: lift the connector latch, insert the cable with the gold contacts facing the correct way and push it fully in, then press the latch down firmly. Check both the Raspberry Pi CAMERA port and the connector on the camera board. After re-seating, power off and power back on (a full power cycle, not a soft reboot), then run sudo python3 7_face_track.py again.
If it still fails, please try a different FPC ribbon cable to rule out a faulty cable.
Please also send us clear photos so we can verify:
(1) the camera module, front and back;
(2) both ends of the FPC cable, showing the gold contact orientation and whether the latch is pressed down;
(3) a close-up of the blue marker at the cable end and the connector latch.
Please upload them to Google Drive (or another cloud service), set the link permission to “Anyone with the link can view”, and send us the link.
Also, please confirm that the release film on the adhesive at the back of the camera component has been peeled off and that the component is pressed firmly onto the PCB.
