Pironman 5 module wont load
cd ~
git clone GitHub - sunfounder/pironman -b v2.0
cd ~/pironman
Cloning into ‘pironman’…
remote: Enumerating objects: 1834, done.
remote: Counting objects: 100% (349/349), done.
remote: Compressing objects: 100% (202/202), done.
error: RPC failed; curl 56 GnuTLS recv error (-9): Error decoding the received TLS packet.
error: 20 bytes of body are still expected
fetch-pack: unexpected disconnect while reading sideband packet
fatal: early EOF
fatal: fetch-pack: invalid index-pack output
That’s the problem, you’ve download software for pironman v2, you need to follow instructions for pironman5, use this link
https://docs.sunfounder.com/projects/pironman5/en/latest/set_up_rpi_os.html
Weirdyguy is absolutely correct. If your product is the pironman5, then the instructions you downloaded and installed are incorrect, indicating that you did not follow the steps provided in the pironman5 tutorial link properly.
We recommend that you follow the steps in the pironman5 tutorial:Set Up Pironman5 on Raspberry Pi/Ubuntu/Kali OS — SunFounder Pironman documentation
Thank you for the reply. I used correct link attempted again .
same problem when i get to here. git clone GitHub - sunfounder/pironman5: Code for Raspberry Pi 5 case (Pironman5)
cd ~/pironman5
Cloning into ‘pironman5’…
remote: Enumerating objects: 1386, done.
remote: Counting objects: 100% (187/187), done.
remote: Compressing objects: 100% (138/138), done.
error: RPC failed; curl 56 Recv failure: Connection reset by peer
error: 1716 bytes of body are still expected
fatal: early EOF
bash: cd: /home/jrcox/pironman5: No such file or directory
python3: can’t open file ‘/home/jrcox/install.py’: [Errno 2] No such file or directory
when i get to here it wont download message.git clone GitHub - sunfounder/pironman5: Code for Raspberry Pi 5 case (Pironman5)
cd ~/pironman5
fatal: early EOF
Everything worked until i get to the github download it stalls a 5 % and then gives attached error
Thanks again or reply.
I’m running newest version of Debian bookworm could that be the problem i don’t see it as supported os ?
Please record a video of the process of downloading and installing the Pironman 5 software. This will help us analyze and resolve the issue more effectively.
If the video file is large, please upload it to OneDrive and share the link with us, ensuring you provide us access permissions.
You can follow the tutorial link for guidance:Set Up on Raspberry Pi/Ubuntu/Kali/Homebridge OS — SunFounder Pironman 5 documentation
