Hello there, I have purchased a pironman 5 case via Amazon and installed the Pironman services via ssh onto batocera 41. Oled display works, the four leds on gpio board wont work at any time and the rgb fans are always on no matter what load.
When I turn it off the fans and oled turn off properly, I changed the according settings.
The batocera config file says fan mode is set to 2.
Is there a solution to get everything running as intended? Batocera is listed as fully compatible with pironman 5.
To resolve this, we recommend trying a different compatible operating system to install the Pironman5 software. Currently, there are some compatibility issues between Batocera and PI5, and we are working with the Batocera development team to address these. However, this process will take some time, as it depends on their update schedule and priorities.
Thank you for your quick response, I am looking forward to the issues being resolved as I would prefer to use batocera but in the meantime, I tried using Raspberry Pi OS with Retropie on top and on the latest build the Pironman 5 software seems to work exactly as intended
