Hi again,
Thank you for the suggestion. We completed the task as requested, but the screen still does not come on, it is still black, and not on.
attached is the entire pironman log file from the first boot, and a link to an image of the front of the pironman showing the screen is black with sudo pironman -al on set.
Photo: Screenshot - 52beb38c266cb0c0f114c2620721fb40 - Gyazo
Log:
/opt/pironman/log
------------------------23/12/27 16:56:54------------------------
pironman version: 2.2.4
username: pi
Kernel Version:
Linux raspberrypi 5.10.17-v7l+ #1414 SMP Fri Apr 30 13:20:47 BST 2021 armv7l GNU/Linux
OS Version:
No LSB modules are available.
Description: Raspbian GNU/Linux 10 (buster)
PCB info:
Revision : d03115
23/12/27 16:56:54,915 [DEBUG] power_key_pin : 16
23/12/27 16:56:54,915 [DEBUG] fan_pin : 6
23/12/27 16:56:54,915 [DEBUG] update_frequency : 0.5
23/12/27 16:56:54,915 [DEBUG] temp_unit : C
23/12/27 16:56:54,916 [DEBUG] fan_temp : 50.0
23/12/27 16:56:54,916 [DEBUG] screen_always_on : False
23/12/27 16:56:54,916 [DEBUG] screen_off_time : 60
23/12/27 16:56:54,916 [DEBUG] rgb_enable : True
23/12/27 16:56:54,916 [DEBUG] rgb_switch: True
23/12/27 16:56:54,916 [DEBUG] rgb_style : breath
23/12/27 16:56:54,916 [DEBUG] rgb_color : 0a1aff
23/12/27 16:56:54,916 [DEBUG] rgb_blink_speed : 50
23/12/27 16:56:54,917 [DEBUG] rgb_pwm_freq : 1000
23/12/27 16:56:54,917 [DEBUG] rgb_pin : 10
23/12/27 16:56:54,956 [DEBUG] oled init success
23/12/27 16:56:54,968 [DEBUG] rgb_show
23/12/27 16:56:54,972 [DEBUG] rgb_show: breath
23/12/27 16:56:55,209 [DEBUG] Got IPs: {‘eth0’: ‘192.168.1.241’, ‘wlan0’: ‘192.168.1.240’}
------------------------23/12/27 16:58:11------------------------
username:
Kernel Version:
OS Version:
PCB info:
Revision : d03115
23/12/27 16:58:11,497 [DEBUG] power_key_pin : 16
23/12/27 16:58:11,497 [DEBUG] fan_pin : 6
23/12/27 16:58:11,497 [DEBUG] update_frequency : 0.5
23/12/27 16:58:11,497 [DEBUG] temp_unit : C
23/12/27 16:58:11,497 [DEBUG] fan_temp : 50.0
23/12/27 16:58:11,498 [DEBUG] screen_always_on : False
23/12/27 16:58:11,498 [DEBUG] screen_off_time : 60
23/12/27 16:58:11,498 [DEBUG] rgb_enable : True
23/12/27 16:58:11,498 [DEBUG] rgb_switch: True
23/12/27 16:58:11,498 [DEBUG] rgb_style : breath
23/12/27 16:58:11,498 [DEBUG] rgb_color : 0a1aff
23/12/27 16:58:11,498 [DEBUG] rgb_blink_speed : 50
23/12/27 16:58:11,498 [DEBUG] rgb_pwm_freq : 1000
23/12/27 16:58:11,499 [DEBUG] rgb_pin : 10
23/12/27 16:58:11,570 [DEBUG] oled init success
23/12/27 16:58:11,586 [DEBUG] rgb_show
23/12/27 16:58:11,587 [DEBUG] rgb_show: breath
23/12/27 16:58:11,851 [DEBUG] Got IPs: {‘eth0’: ‘’, ‘wlan0’: ‘’}
23/12/27 16:58:12,763 [DEBUG] Got IPs: {‘eth0’: ‘’, ‘wlan0’: ‘’}
23/12/27 16:58:13,673 [DEBUG] Got IPs: {‘eth0’: ‘’, ‘wlan0’: ‘’}
23/12/27 16:58:14,628 [DEBUG] Got IPs: {‘eth0’: ‘192.168.1.241’, ‘wlan0’: ‘’}
------------------------23/12/27 23:35:55------------------------
username:
Kernel Version:
OS Version:
PCB info:
Revision : d03115
23/12/27 23:35:55,353 [DEBUG] power_key_pin : 16
23/12/27 23:35:55,353 [DEBUG] fan_pin : 6
23/12/27 23:35:55,354 [DEBUG] update_frequency : 0.5
23/12/27 23:35:55,354 [DEBUG] temp_unit : C
23/12/27 23:35:55,354 [DEBUG] fan_temp : 50.0
23/12/27 23:35:55,354 [DEBUG] screen_always_on : False
23/12/27 23:35:55,355 [DEBUG] screen_off_time : 60
23/12/27 23:35:55,355 [DEBUG] rgb_enable : True
23/12/27 23:35:55,355 [DEBUG] rgb_switch: True
23/12/27 23:35:55,355 [DEBUG] rgb_style : breath
23/12/27 23:35:55,355 [DEBUG] rgb_color : 0a1aff
23/12/27 23:35:55,355 [DEBUG] rgb_blink_speed : 50
23/12/27 23:35:55,355 [DEBUG] rgb_pwm_freq : 1000
23/12/27 23:35:55,355 [DEBUG] rgb_pin : 10
23/12/27 23:35:55,356 [DEBUG]
23/12/27 23:35:55,425 [DEBUG] oled init success
23/12/27 23:35:55,441 [DEBUG] rgb_show
23/12/27 23:35:55,441 [DEBUG] rgb_show: breath
23/12/27 23:35:55,704 [DEBUG] Got IPs: {‘eth0’: ‘’, ‘wlan0’: ‘’}
23/12/27 23:35:56,654 [DEBUG] Got IPs: {‘eth0’: ‘’, ‘wlan0’: ‘’}
23/12/27 23:35:57,571 [DEBUG] Got IPs: {‘eth0’: ‘’, ‘wlan0’: ‘’}
23/12/27 23:35:58,532 [DEBUG] Got IPs: {‘eth0’: ‘’, ‘wlan0’: ‘’}
23/12/27 23:35:59,447 [DEBUG] Got IPs: {‘eth0’: ‘’, ‘wlan0’: ‘’}
23/12/27 23:36:00,365 [DEBUG] Got IPs: {‘eth0’: ‘’, ‘wlan0’: ‘’}
23/12/27 23:36:01,274 [DEBUG] Got IPs: {‘eth0’: ‘192.168.1.241’, ‘wlan0’: ‘’}
------------------------23/12/28 06:51:10------------------------
username:
OS Version:
PCB info:
Revision : d03115
23/12/28 06:51:11,174 [DEBUG] power_key_pin : 16
23/12/28 06:51:11,174 [DEBUG] fan_pin : 6
23/12/28 06:51:11,175 [DEBUG] update_frequency : 0.5
23/12/28 06:51:11,175 [DEBUG] temp_unit : C
23/12/28 06:51:11,175 [DEBUG] fan_temp : 50.0
23/12/28 06:51:11,175 [DEBUG] screen_always_on : False
23/12/28 06:51:11,175 [DEBUG] screen_off_time : 60
23/12/28 06:51:11,175 [DEBUG] rgb_enable : True
23/12/28 06:51:11,175 [DEBUG] rgb_switch: True
23/12/28 06:51:11,176 [DEBUG] rgb_style : breath
23/12/28 06:51:11,176 [DEBUG] rgb_color : 0a1aff
23/12/28 06:51:11,176 [DEBUG] rgb_blink_speed : 50
23/12/28 06:51:11,176 [DEBUG] rgb_pwm_freq : 1000
23/12/28 06:51:11,176 [DEBUG] rgb_pin : 10
23/12/28 06:51:11,245 [DEBUG] oled init success
23/12/28 06:51:11,258 [DEBUG] rgb_show
23/12/28 06:51:11,262 [DEBUG] rgb_show: breath
23/12/28 06:51:11,538 [DEBUG] Got IPs: {‘eth0’: ‘’, ‘wlan0’: ‘’}
23/12/28 06:51:12,490 [DEBUG] Got IPs: {‘eth0’: ‘’, ‘wlan0’: ‘’}
23/12/28 06:51:13,405 [DEBUG] Got IPs: {‘eth0’: ‘’, ‘wlan0’: ‘’}
23/12/28 06:51:14,317 [DEBUG] Got IPs: {‘eth0’: ‘’, ‘wlan0’: ‘’}
23/12/28 06:51:15,212 [DEBUG] Got IPs: {‘eth0’: ‘192.168.1.241’, ‘wlan0’: ‘192.168.1.240’}
------------------------23/12/28 21:42:09------------------------
username: pi
Kernel Version:
OS Version:
PCB info:
Revision : d03115
23/12/28 21:42:09,779 [DEBUG] power_key_pin : 16
23/12/28 21:42:09,780 [DEBUG] fan_pin : 6
23/12/28 21:42:09,780 [DEBUG] update_frequency : 0.5
23/12/28 21:42:09,780 [DEBUG] temp_unit : C
23/12/28 21:42:09,780 [DEBUG] fan_temp : 50.0
23/12/28 21:42:09,780 [DEBUG] screen_always_on : False
23/12/28 21:42:09,780 [DEBUG] screen_off_time : 60
23/12/28 21:42:09,780 [DEBUG] rgb_enable : True
23/12/28 21:42:09,780 [DEBUG] rgb_switch: True
23/12/28 21:42:09,781 [DEBUG] rgb_style : leap
23/12/28 21:42:09,781 [DEBUG] rgb_color : 0a1aff
23/12/28 21:42:09,781 [DEBUG] rgb_blink_speed : 50
23/12/28 21:42:09,781 [DEBUG] rgb_pwm_freq : 1000
23/12/28 21:42:09,781 [DEBUG] rgb_pin : 10
23/12/28 21:42:09,821 [DEBUG] oled init success
23/12/28 21:42:09,837 [DEBUG] rgb_show
23/12/28 21:42:09,837 [DEBUG] rgb_show: leap
23/12/28 21:42:10,070 [DEBUG] Got IPs: {‘eth0’: ‘192.168.1.241’, ‘wlan0’: ‘192.168.1.240’}
------------------------23/12/28 21:42:25------------------------
username: pi
Kernel Version:
OS Version:
PCB info:
Revision : d03115
23/12/28 21:42:25,831 [DEBUG] power_key_pin : 16
23/12/28 21:42:25,831 [DEBUG] fan_pin : 6
23/12/28 21:42:25,831 [DEBUG] update_frequency : 0.5
23/12/28 21:42:25,831 [DEBUG] temp_unit : C
23/12/28 21:42:25,831 [DEBUG] fan_temp : 50.0
23/12/28 21:42:25,831 [DEBUG] screen_always_on : False
23/12/28 21:42:25,831 [DEBUG] screen_off_time : 60
23/12/28 21:42:25,832 [DEBUG] rgb_enable : True
23/12/28 21:42:25,832 [DEBUG] rgb_switch: True
23/12/28 21:42:25,832 [DEBUG] rgb_style : flow
23/12/28 21:42:25,832 [DEBUG] rgb_color : 0a1aff
23/12/28 21:42:25,832 [DEBUG] rgb_blink_speed : 50
23/12/28 21:42:25,832 [DEBUG] rgb_pwm_freq : 1000
23/12/28 21:42:25,832 [DEBUG] rgb_pin : 10
23/12/28 21:42:25,873 [DEBUG] oled init success
23/12/28 21:42:25,888 [DEBUG] rgb_show
23/12/28 21:42:25,889 [DEBUG] rgb_show: flow
23/12/28 21:42:26,122 [DEBUG] Got IPs: {‘eth0’: ‘192.168.1.241’, ‘wlan0’: ‘192.168.1.240’}
------------------------23/12/28 21:42:48------------------------
username: pi
Kernel Version:
OS Version:
PCB info:
Revision : d03115
23/12/28 21:42:48,356 [DEBUG] power_key_pin : 16
23/12/28 21:42:48,356 [DEBUG] fan_pin : 6
23/12/28 21:42:48,356 [DEBUG] update_frequency : 0.5
23/12/28 21:42:48,356 [DEBUG] temp_unit : C
23/12/28 21:42:48,357 [DEBUG] fan_temp : 50.0
23/12/28 21:42:48,357 [DEBUG] screen_always_on : False
23/12/28 21:42:48,357 [DEBUG] screen_off_time : 60
23/12/28 21:42:48,357 [DEBUG] rgb_enable : True
23/12/28 21:42:48,357 [DEBUG] rgb_switch: True
23/12/28 21:42:48,357 [DEBUG] rgb_style : raise_up
23/12/28 21:42:48,357 [DEBUG] rgb_color : 0a1aff
23/12/28 21:42:48,357 [DEBUG] rgb_blink_speed : 50
23/12/28 21:42:48,358 [DEBUG] rgb_pwm_freq : 1000
23/12/28 21:42:48,358 [DEBUG] rgb_pin : 10
23/12/28 21:42:48,397 [DEBUG] oled init success
23/12/28 21:42:48,412 [DEBUG] rgb_show
23/12/28 21:42:48,412 [DEBUG] rgb_show: raise_up
23/12/28 21:42:48,646 [DEBUG] Got IPs: {‘eth0’: ‘192.168.1.241’, ‘wlan0’: ‘192.168.1.240’}
------------------------23/12/28 21:43:07------------------------
username: pi
Kernel Version:
OS Version:
PCB info:
Revision : d03115
23/12/28 21:43:07,987 [DEBUG] power_key_pin : 16
23/12/28 21:43:07,987 [DEBUG] fan_pin : 6
23/12/28 21:43:07,988 [DEBUG] update_frequency : 0.5
23/12/28 21:43:07,988 [DEBUG] temp_unit : C
23/12/28 21:43:07,988 [DEBUG] fan_temp : 50.0
23/12/28 21:43:07,988 [DEBUG] screen_always_on : False
23/12/28 21:43:07,988 [DEBUG] screen_off_time : 60
23/12/28 21:43:07,988 [DEBUG] rgb_enable : True
23/12/28 21:43:07,988 [DEBUG] rgb_switch: True
23/12/28 21:43:07,988 [DEBUG] rgb_style : colorful
23/12/28 21:43:07,988 [DEBUG] rgb_color : 0a1aff
23/12/28 21:43:07,989 [DEBUG] rgb_blink_speed : 50
23/12/28 21:43:07,989 [DEBUG] rgb_pwm_freq : 1000
23/12/28 21:43:07,989 [DEBUG] rgb_pin : 10
23/12/28 21:43:08,027 [DEBUG] oled init success
23/12/28 21:43:08,042 [DEBUG] rgb_show
23/12/28 21:43:08,043 [DEBUG] rgb_show: colorful
23/12/28 21:43:08,276 [DEBUG] Got IPs: {‘eth0’: ‘192.168.1.241’, ‘wlan0’: ‘192.168.1.240’}
------------------------23/12/28 21:43:25------------------------
username: pi
Kernel Version:
OS Version:
PCB info:
Revision : d03115
23/12/28 21:43:25,297 [DEBUG] power_key_pin : 16
23/12/28 21:43:25,297 [DEBUG] fan_pin : 6
23/12/28 21:43:25,297 [DEBUG] update_frequency : 0.5
23/12/28 21:43:25,297 [DEBUG] temp_unit : C
23/12/28 21:43:25,298 [DEBUG] fan_temp : 50.0
23/12/28 21:43:25,298 [DEBUG] screen_always_on : False
23/12/28 21:43:25,298 [DEBUG] screen_off_time : 60
23/12/28 21:43:25,298 [DEBUG] rgb_enable : True
23/12/28 21:43:25,298 [DEBUG] rgb_switch: True
23/12/28 21:43:25,298 [DEBUG] rgb_style : colorful_leap
23/12/28 21:43:25,298 [DEBUG] rgb_color : 0a1aff
23/12/28 21:43:25,298 [DEBUG] rgb_blink_speed : 50
23/12/28 21:43:25,299 [DEBUG] rgb_pwm_freq : 1000
23/12/28 21:43:25,299 [DEBUG] rgb_pin : 10
23/12/28 21:43:25,337 [DEBUG] oled init success
23/12/28 21:43:25,352 [DEBUG] rgb_show
23/12/28 21:43:25,353 [DEBUG] rgb_show: colorful_leap
23/12/28 21:43:25,585 [DEBUG] Got IPs: {‘eth0’: ‘192.168.1.241’, ‘wlan0’: ‘192.168.1.240’}
------------------------23/12/28 21:43:38------------------------
username: pi
Kernel Version:
OS Version:
PCB info:
Revision : d03115
23/12/28 21:43:39,081 [DEBUG] power_key_pin : 16
23/12/28 21:43:39,081 [DEBUG] fan_pin : 6
23/12/28 21:43:39,081 [DEBUG] update_frequency : 0.5
23/12/28 21:43:39,082 [DEBUG] temp_unit : C
23/12/28 21:43:39,082 [DEBUG] fan_temp : 50.0
23/12/28 21:43:39,082 [DEBUG] screen_always_on : False
23/12/28 21:43:39,082 [DEBUG] screen_off_time : 60
23/12/28 21:43:39,082 [DEBUG] rgb_enable : True
23/12/28 21:43:39,082 [DEBUG] rgb_switch: True
23/12/28 21:43:39,082 [DEBUG] rgb_style : colorful
23/12/28 21:43:39,082 [DEBUG] rgb_color : 0a1aff
23/12/28 21:43:39,082 [DEBUG] rgb_blink_speed : 50
23/12/28 21:43:39,083 [DEBUG] rgb_pwm_freq : 1000
23/12/28 21:43:39,083 [DEBUG] rgb_pin : 10
23/12/28 21:43:39,122 [DEBUG] oled init success
23/12/28 21:43:39,137 [DEBUG] rgb_show
23/12/28 21:43:39,138 [DEBUG] rgb_show: colorful
23/12/28 21:43:39,371 [DEBUG] Got IPs: {‘eth0’: ‘192.168.1.241’, ‘wlan0’: ‘192.168.1.240’}
------------------------23/12/28 21:55:53------------------------
username:
Kernel Version:
OS Version:
PCB info:
Revision : d03115
23/12/28 21:55:53,366 [DEBUG] power_key_pin : 16
23/12/28 21:55:53,366 [DEBUG] fan_pin : 6
23/12/28 21:55:53,366 [DEBUG] update_frequency : 0.5
23/12/28 21:55:53,366 [DEBUG] temp_unit : C
23/12/28 21:55:53,366 [DEBUG] fan_temp : 50.0
23/12/28 21:55:53,366 [DEBUG] screen_always_on : False
23/12/28 21:55:53,367 [DEBUG] screen_off_time : 60
23/12/28 21:55:53,367 [DEBUG] rgb_enable : True
23/12/28 21:55:53,367 [DEBUG] rgb_switch: True
23/12/28 21:55:53,367 [DEBUG] rgb_style : colorful
23/12/28 21:55:53,367 [DEBUG] rgb_color : 0a1aff
23/12/28 21:55:53,367 [DEBUG] rgb_blink_speed : 50
23/12/28 21:55:53,367 [DEBUG] rgb_pwm_freq : 1000
23/12/28 21:55:53,367 [DEBUG] rgb_pin : 10
23/12/28 21:55:53,422 [DEBUG] oled init failed:
[Errno 121] Remote I/O error
23/12/28 21:55:53,438 [DEBUG] rgb_show
23/12/28 21:55:53,439 [DEBUG] rgb_show: colorful
------------------------23/12/28 22:06:29------------------------
username: pi
Kernel Version:
OS Version:
PCB info:
Revision : d03115
23/12/28 22:06:29,233 [DEBUG] power_key_pin : 16
23/12/28 22:06:29,234 [DEBUG] fan_pin : 6
23/12/28 22:06:29,234 [DEBUG] update_frequency : 0.5
23/12/28 22:06:29,234 [DEBUG] temp_unit : C
23/12/28 22:06:29,234 [DEBUG] fan_temp : 50.0
23/12/28 22:06:29,234 [DEBUG] screen_always_on : True
23/12/28 22:06:29,234 [DEBUG] screen_off_time : 60
23/12/28 22:06:29,234 [DEBUG] rgb_enable : True
23/12/28 22:06:29,235 [DEBUG] rgb_switch: True
23/12/28 22:06:29,235 [DEBUG] rgb_style : colorful
23/12/28 22:06:29,235 [DEBUG] rgb_color : 0a1aff
23/12/28 22:06:29,235 [DEBUG] rgb_blink_speed : 50
23/12/28 22:06:29,235 [DEBUG] rgb_pwm_freq : 1000
23/12/28 22:06:29,235 [DEBUG] rgb_pin : 10
23/12/28 22:06:29,265 [DEBUG] oled init failed:
23/12/28 22:06:29,280 [DEBUG] rgb_show
23/12/28 22:06:29,281 [DEBUG] rgb_show: colorful
------------------------23/12/28 22:06:53------------------------
username:
OS Version:
PCB info:
Revision : d03115
23/12/28 22:06:53,258 [DEBUG] power_key_pin : 16
23/12/28 22:06:53,258 [DEBUG] fan_pin : 6
23/12/28 22:06:53,259 [DEBUG] update_frequency : 0.5
23/12/28 22:06:53,259 [DEBUG] temp_unit : C
23/12/28 22:06:53,259 [DEBUG] fan_temp : 50.0
23/12/28 22:06:53,259 [DEBUG] screen_always_on : True
23/12/28 22:06:53,259 [DEBUG] screen_off_time : 60
23/12/28 22:06:53,259 [DEBUG] rgb_enable : True
23/12/28 22:06:53,259 [DEBUG] rgb_switch: True
23/12/28 22:06:53,259 [DEBUG] rgb_style : colorful
23/12/28 22:06:53,260 [DEBUG] rgb_color : 0a1aff
23/12/28 22:06:53,260 [DEBUG] rgb_blink_speed : 50
23/12/28 22:06:53,260 [DEBUG] rgb_pwm_freq : 1000
23/12/28 22:06:53,260 [DEBUG] rgb_pin : 10
23/12/28 22:06:53,331 [DEBUG] oled init success
23/12/28 22:06:53,347 [DEBUG] rgb_show
23/12/28 22:06:53,347 [DEBUG] rgb_show: colorful
23/12/28 22:06:53,614 [DEBUG] Got IPs: {‘eth0’: ‘’, ‘wlan0’: ‘’}
23/12/28 22:06:54,522 [DEBUG] Got IPs: {‘eth0’: ‘’, ‘wlan0’: ‘’}
23/12/28 22:06:55,394 [DEBUG] Got IPs: {‘eth0’: ‘’, ‘wlan0’: ‘’}
23/12/28 22:06:56,264 [DEBUG] Got IPs: {‘eth0’: ‘192.168.1.241’, ‘wlan0’: ‘’}
------------------------23/12/28 22:22:12------------------------
username: pi
Kernel Version:
OS Version:
PCB info:
Revision : d03115
23/12/28 22:22:12,996 [DEBUG] power_key_pin : 16
23/12/28 22:22:12,996 [DEBUG] fan_pin : 6
23/12/28 22:22:12,996 [DEBUG] update_frequency : 0.5
23/12/28 22:22:12,996 [DEBUG] temp_unit : C
23/12/28 22:22:12,996 [DEBUG] fan_temp : 50.0
23/12/28 22:22:12,996 [DEBUG] screen_always_on : True
23/12/28 22:22:12,996 [DEBUG] screen_off_time : 60
23/12/28 22:22:12,996 [DEBUG] rgb_enable : True
23/12/28 22:22:12,997 [DEBUG] rgb_switch: True
23/12/28 22:22:12,997 [DEBUG] rgb_style : colorful
23/12/28 22:22:12,997 [DEBUG] rgb_color : 0a1aff
23/12/28 22:22:12,997 [DEBUG] rgb_blink_speed : 50
23/12/28 22:22:12,997 [DEBUG] rgb_pwm_freq : 1000
23/12/28 22:22:12,997 [DEBUG] rgb_pin : 10
23/12/28 22:22:13,036 [DEBUG] oled init success
23/12/28 22:22:13,052 [DEBUG] rgb_show
23/12/28 22:22:13,052 [DEBUG] rgb_show: colorful
23/12/28 22:22:13,289 [DEBUG] Got IPs: {‘eth0’: ‘192.168.1.241’, ‘wlan0’: ‘192.168.1.240’}
