For those that want to install the NEW fusion HAT+ on Pi5 running Ubuntu 24.04 (to run ROS2), setting the shutdown behaviour is not as straightforward as Pi5 running PiOS (see user guide Quick User Guide — SunFounder Fusion HAT+ documentation ) . There are two issues when I tried. Firstly, raspi-config utility is not installed with Ubuntu. This can be installed using:
sudo apt install raspi-config
Second, when running raspi-config, changing the shutdown behaviour is not an option in the ADVANCED OPTIONS menu (see screenshot)
Solution:
You can manually set the shutdown behaviour by editing the EEPROM configuraton using CLI.
- Open the EEPROM using the
--editflag
sudo rpi-eeprom-config --edit
- Locate and edit or add the following line under [all]:
POWER_OFF_ON_HALT=1
This will set the shutdown behaviour =1 to full power off
To save and exit (Press
Ctrl-X, thenYand thenENTER) -
Reboot
