The laser sensor module
can an raspberry pi smart pi touch 2 activate the laser sensor module, its from Amazon.com: Acxico 2Sets Laser Sensor Module For Arduino AVR(KY-008 Laser Transmitter +Laser Receiver Sensor Module Non-modulator Tube) : Electronics if so, then tell me, thanks!
In theory, the laser sensor module should be able to work with the Raspberry Pi, but it requires you to make the hardware connection, write the code for it, and then run it. If you do all of that, the laser sensor module should be able to work normally.
can you show me an example of a code for activating a laser senor module?
You can refer to our tutorial:Laser Emitter Module - Wiki
