Calibrate.py script missing
Setting up a picar-x and there is no calibrate.py script after the installation so cannot correct the slight deviation in the steering alignment. Two issues really. Anyone else found this, and anyone know where I can get a copy. It isn’t in the examples folder as shown in the documentation and a full scan of the files system (sudo find / -name calibrate.py -print) and not to be found.
Cheers
Did you follow our tutorial steps to install all the libraries.
It is possible that you installed the picar-x libraries in the wrong branch, you should have installed the v2.0 branch instead of the main branch master.
Please follow our tutorial link to download and install the libraries:
https://docs.sunfounder.com/projects/picar-x/en/latest/python/python_start/install_all_modules.html
