Installing Robot HAT v4 on Ubuntu
I have double checked the install.py file and i2samp.sh script and reviewed the breif notes I made at the time and I think just a few simple steps should successfully install a robot-HAT v4 on a Raspberry Pi 5 runnung Ubuntu 24.04
1) Clone robot hat repository to home directory (follow instructions on Sunfounder website)
cd ~/ git clone -b v2.0 https://github.com/sunfounder/robot-hat.git cd robot-hat
- DO NOT run the
instal.pyfile as it will fail - Install required packages and setup manually as below
2) Install required packages from APT repository
raspi-config (not bundled in Ubuntu 24.04)
i2c-tools
espeak
libsdl2-dev
libsdl2-mixer-dev
portaudio19-dev
sox
sudo apt install raspi-config i2c-tools espeak libsdl2-dev libsdl2-mixer- dev portaudio19-dev sox
3) Install required python packages
smbus2
gpiozero
pyaudio
spidev
pyserial (package not on apt. Use python3-serial instead)
pillow (newest version python3-pil with ubuntu and is automatically selected instead
by apt)
pygame>=2.1.2 (was unable to install version 2.1.2 from apt. used python3-pygame
instead which downloads v2.5.2-2 instead)
I installed each package system-wide using:
sudo apt install python3-<PACKAGE_NAME>
If installing into a virtual environment, use pip instead
python3 -m pip install <PACKAGE_NAME>
4) Enable I2C and SPI interfaces
Open raspberry pi configuration tool by typing following into terminal
sudo rasp-config -
Select option 3 - Interface options and enable I2C and SPI
5) Copy hardware dtoverlays to overlays directory
Copy required harware overlays from within
robot-hatdirectory to/boot/firmware/overlays/directory -
cd robot-hat -
cp ./dtoverlays/* /boot/firmware/overlays/ -
This will copy
sunfounder-robothat5.dtboandsunfounder-servohat+.dtboto the directory -
Edit
config.txtto apply these overlays at time of boot -
cd ~/ sudo nano /boot/firmware/config.txt -
Add the following lines to
config.txtafter the[All] -
dtoverlay=sunfounder-robothat5 dtoverlay=sunfounder-servohat+ -
Exit with
ctrl-XandYto save changes
6) Reboot and try python programs in test folder
NOTE: you MUST copy the
robot_hatfolder (robot_hat module) into thetestsfolder for the python testing programs to work -
Motor and servo demo files should now work
Sound card setup and audio testing follows separately
