I’ve had a look at the install.py file and I think I can see where is goes wrong at line 89:
def check_raspbain_version():
_, result = run_command("cat /etc/debian_version|awk -F. '{print $1}'")
return int(result.strip())
You would expect it returns a 13 for the Debian version and not a string. I can’t check it as I haven’t got 13 installed anywhere yet.
The script seems to only using the debian version to determine which version of libttspico-utils to install for pico2wave TTS package.
# Dependencies list installed with apt
APT_INSTALL_LIST = [
'raspi-config',
"i2c-tools",
"espeak",
'libsdl2-dev',
'libsdl2-mixer-dev',
'portaudio19-dev', # pyaudio
'sox',
if raspbain_version in [12] and os_bit == 64:
APT_INSTALL_LIST.append("libttspico-utils") # tts -> pico2wave
For version 12 should just add libttspico-utils to the list of packages to install with apt
Later in the script, if libttspico-utils is not in the APT_INSTALL_LIST, a specific version of libttspico and libttspico-utils is installed for debian versions 12 or above >=12 :
if 'libttspico-utils' not in APT_INSTALL_LIST:
_pool = 'http://ftp.debian.org/debian/pool/non-free/s/svox/'
if raspbain_version >= 12:
libttspico= 'libttspico0t64_1.0+git20130326-14.1_armhf.deb'
libttspico_utils = 'libttspico-utils_1.0+git20130326-14.1_armhf.deb'
elif raspbain_version < 12:
libttspico = 'libttspico0_1.0+git20130326-11_armhf.deb'
libttspico_utils = 'libttspico-utils_1.0+git20130326-11_armhf.deb'
do(msg="install pico2wave",
cmd=f'wget {_pool}{libttspico}' +
f' &&wget {_pool}{libttspico_utils}' +
f' && apt-get install -f ./{libttspico} ./{libttspico_utils} -y'
Assuming the above script installs the correct versions for debian 13 (it looks like it that is the intention), then editing the install.py file to return 13 for the version check might just allow the script to run.
# comment out original code and simply return 13
# _, result = run_command("cat /etc/debian_version|awk -F. '{print $1}'")
# return int(result.strip())
return 13
Obviously I cannot verify if it would work or cause other unintended issues, but might be worth a try?
