Assembled pironman5 but when I turn on this is the message after the raspberry pi operating system box comes on.
There is an issue with SD card extender, or a bad SD card, but if it work when you put SD card directly into Rpi5. Issue with extender.
Yea that’s what it is. I removed the ss card extender and then it booted. Added it back no boot. Also the screen isn’t working. Anything you have to do to get that to come on?
For the SD card extender, you need to contact the customer service at service@sunfounder.com , they’ll send you a replacement part.
For the screen, you mean there’s no display with 2 HDMI output? Have you try different HDMI cable? Did USB \ HDMI adapter is well connect with Rpi5?
The little oled screen is what I’m referring to. It’s blank like it’s getting no power. I’ve reseated the ribbon but still no picture.
Did you install Pironman5 software?
Which OS are you using?
The normal one from the raspberry pi website. The recommended 64 bit os
Have not downloaded the Pironman software. Did not see that on the installation guide
You need to install it for OLED, 2 RGB cooling fan and case LEDs control.
- You need to install our compatible system. (as shown in the picture)
After our testing, there are currently two systems with our pironman5 software installed and the OLED screen does not work properly, the systems are as follows:
Raspberry Pi OS lite - bookworm 32 bit 2024-11-19
Homebridge OS 32 bit 2024-12-19
Other systems are compatible with pironman5 software, we will fix the compatibility problem of these two systems as soon as possible.
3. Install the pironman5 software, not the pironman software, don’t get confused.
Weirdyguy is correct, you need to install pironman5 software for OLED, 2 RGB cooling fans and case LED control.
