Guys i get this error when trying to make calibration. I am new to forums and this kind of robotic.
File “/home/****/pidog/examples/0_calibration.py”, line 2, in
from pidog import Pidog
File “/usr/local/lib/python3.13/dist-packages/pidog/init.py”, line 2, in
from .pidog import Pidog
File “/usr/local/lib/python3.13/dist-packages/pidog/pidog.py”, line 9, in
from robot_hat import Robot, Pin, Ultrasonic, utils, Music, I2C
ModuleNotFoundError: No module named ‘robot_hat’
1. Is your battery properly connected to the robot hat? 2. Is the battery sufficiently charged? 3. After connecting the battery to the robot hat, have you turned on the power switch to supply power? 4. Have you downloaded and installed the correct library code?
