Compilation error: ‘ledcSetup’ and 'ledcAttachPin' was not declared in this scope please help me
I’m working through the ESP32-38 pin wide. I was building a gyroscope controlled robot car.
this is my code -
#include <esp_now.h>
#include <WiFi.h>
#define FORWARD 1
#define BACKWARD 2
#define LEFT 3
#define RIGHT 4
#define FORWARD_LEFT 5
#define FORWARD_RIGHT 6
#define BACKWARD_LEFT 7
#define BACKWARD_RIGHT 8
#define TURN_LEFT 9
#define TURN_RIGHT 10
#define STOP 0
#define BACK_RIGHT_MOTOR 0
#define BACK_LEFT_MOTOR 1
#define FRONT_RIGHT_MOTOR 2
#define FRONT_LEFT_MOTOR 3
struct MOTOR_PINS
int pinIN1;
int pinIN2;
int pinEn;
int pwmSpeedChannel;
std::vector<MOTOR_PINS> motorPins =
{16, 17, 22, 4}, //BACK_RIGHT_MOTOR
{18, 19, 23, 5}, //BACK_LEFT_MOTOR
{26, 27, 14, 6}, //FRONT_RIGHT_MOTOR
{33, 25, 32, 7}, //FRONT_LEFT_MOTOR
#define MAX_MOTOR_SPEED 200
const int PWMFreq = 1000; /* 1 KHz */
const int PWMResolution = 8;
#define SIGNAL_TIMEOUT 1000 // This is signal timeout in milli seconds. We will reset the data if no signal
unsigned long lastRecvTime = 0;
struct PacketData
byte xAxisValue;
byte yAxisValue;
byte zAxisValue;
PacketData receiverData;
// callback function that will be executed when data is received
void OnDataRecv(const uint8_t * mac, const uint8_t *incomingData, int len)
if (len == 0)
return;
memcpy(&receiverData, incomingData, sizeof(receiverData));
String inputData ;
inputData = inputData + "values " + receiverData.xAxisValue + " " + receiverData.yAxisValue + " " + receiverData.zAxisValue;
Serial.println(inputData);
if ( receiverData.xAxisValue < 75 && receiverData.yAxisValue < 75)
processCarMovement(FORWARD_LEFT);
else if ( receiverData.xAxisValue > 175 && receiverData.yAxisValue < 75)
processCarMovement(FORWARD_RIGHT);
else if ( receiverData.xAxisValue < 75 && receiverData.yAxisValue > 175)
processCarMovement(BACKWARD_LEFT);
else if ( receiverData.xAxisValue > 175 && receiverData.yAxisValue > 175)
processCarMovement(BACKWARD_RIGHT);
else if (receiverData.zAxisValue > 175)
processCarMovement(TURN_RIGHT);
else if (receiverData.zAxisValue < 75)
processCarMovement(TURN_LEFT);
else if (receiverData.yAxisValue < 75)
processCarMovement(FORWARD);
else if (receiverData.yAxisValue > 175)
processCarMovement(BACKWARD);
else if (receiverData.xAxisValue > 175)
processCarMovement(RIGHT);
else if (receiverData.xAxisValue < 75)
processCarMovement(LEFT);
else
processCarMovement(STOP);
lastRecvTime = millis();
void processCarMovement(int inputValue)
switch(inputValue)
case FORWARD:
rotateMotor(FRONT_RIGHT_MOTOR, MAX_MOTOR_SPEED);
rotateMotor(BACK_RIGHT_MOTOR, MAX_MOTOR_SPEED);
rotateMotor(FRONT_LEFT_MOTOR, MAX_MOTOR_SPEED);
rotateMotor(BACK_LEFT_MOTOR, MAX_MOTOR_SPEED);
break;
case BACKWARD:
  rotateMotor(FRONT_RIGHT_MOTOR, -MAX_MOTOR_SPEED);
  rotateMotor(BACK_RIGHT_MOTOR, -MAX_MOTOR_SPEED);
  rotateMotor(FRONT_LEFT_MOTOR, -MAX_MOTOR_SPEED);
  rotateMotor(BACK_LEFT_MOTOR, -MAX_MOTOR_SPEED);
  break;
case LEFT:
  break;
case RIGHT:
  break;
case FORWARD_LEFT:
  rotateMotor(BACK_RIGHT_MOTOR, STOP);
  rotateMotor(FRONT_LEFT_MOTOR, STOP);
  break;
case FORWARD_RIGHT:
  rotateMotor(FRONT_RIGHT_MOTOR, STOP);
  rotateMotor(BACK_LEFT_MOTOR, STOP);
  break;
case BACKWARD_LEFT:
  break;
case BACKWARD_RIGHT:
  break;
case TURN_LEFT:
  break;
case TURN_RIGHT:
  break;
case STOP:
  break;
default:
  break;
void rotateMotor(int motorNumber, int motorSpeed)
if (motorSpeed < 0)
digitalWrite(motorPins[motorNumber].pinIN1, LOW);
digitalWrite(motorPins[motorNumber].pinIN2, HIGH);
else if (motorSpeed > 0)
digitalWrite(motorPins[motorNumber].pinIN1, HIGH);
digitalWrite(motorPins[motorNumber].pinIN2, LOW);
else
ledcWrite(motorPins[motorNumber].pwmSpeedChannel, abs(motorSpeed));
void setUpPinModes()
for (int i = 0; i < motorPins.size(); i++)
pinMode(motorPins[i].pinIN1, OUTPUT);
pinMode(motorPins[i].pinIN2, OUTPUT);
//Set up PWM for motor speed
ledcSetup(motorPins[i].pwmSpeedChannel, PWMFreq, PWMResolution);
ledcAttachPin(motorPins[i].pinEn, motorPins[i].pwmSpeedChannel);
rotateMotor(i, STOP);
void setup()
setUpPinModes();
Serial.begin(115200);
WiFi.mode(WIFI_STA);
// Init ESP-NOW
if (esp_now_init() != ESP_OK)
Serial.println(“Error initializing ESP-NOW”);
return;
esp_now_register_recv_cb(OnDataRecv);
void loop()
//Check Signal lost.
unsigned long now = millis();
if ( now - lastRecvTime > SIGNAL_TIMEOUT )
keep showing error of ‘ledcSetup’ and ‘ledcAttachPin’
please tell me how to solve it…
This was reported some time ago by another user. Im not sure if Sunfounder fixed it or not.
This was the original suggestion if it helps?
I assume by now it is fixed, but just in case!
Okay, I’ll see if esp32 2.0.14 installs if I follow that.
