I am using EZBlock on a PiCar. Where can I get more instruction on the EZBlock language in general. For instance how can I add a volume adjustment to the Say command or other sound commands.
Also the sound is working but the maximun volume is too low, is there any hardware mod to increase it - in this case the sound command is already set to 100% and higher settings have no effect
Could you please let us know the current volume level of your speaker? Additionally, if possible, we recommend providing a video of the issue, as this will help us analyze and resolve the problem more effectively.
In the meantime, you can try the following steps to adjust the volume:
- Remote SSH Connection: Connect to your robot’s IP address via SSH.
- Adjust Volume: In the command line, run the
alsamixercommand and adjust the volume to the maximum level. - Check Performance: After adjusting the volume, test the speaker again to see if the issue is resolved.
