I tried installing and I am getting the following error below:
E: Unable to locate package linux-headers-raspi
Not sure how to install the package above as I tried to find it and does not exist in the latest raspian.
Distributor ID: Debian
Description: Debian GNU/Linux 13 (trixie)
Release: 13
Codename: trixie
Please let me know how I can get this fixed or what I can do to resolve.
Thanks!
To help us reproduce and resolve the issue, could you please let us know:Which installation command or script were you running when you encountered error?Knowing the exact step will allow us to replicate the problem and find a solution for you.We look forward to your reply.
I ran this command:
curl -sSL "https://raw.githubusercontent.com/sunfounder/pironman5/v1/install.sh" | sudo bash
After doing the latest updates and it did not work. However, I just did a fresh install of the OS and was able to get it installed without issue this time. Not sure what the issue was but now it is working.
Thanks!
It sounds like the problem was likely caused by a compatibility issue with the previous system environment, perhaps due to some leftover packages or configuration conflicts. Since everything is working now, you should be all set.
If you run into any other questions, feel free to ask.
