I installed the Pipower 5 hat to tjhe 40 pin GPIO exposed on the side of the case with the power remaining connected to the Raspberry 5 USB C port.
I then ran the script for the pironman5 and Pipoer 5 drives as instructed in the docs for the pironman5 with a pipower 5 attached and received an install error.
I ran the script with my currently installed pronman5 driver installed and up and running.
My Raspberry Pi 5 environment with the Ironman 5 case:
xxxxxxxxx$ cat /etc/os-release
PRETTY_NAME=“Debian GNU/Linux 13 (trixie)”
NAME=“Debian GNU/Linux”
VERSION_ID=“13”
VERSION=“13 (trixie)”
VERSION_CODENAME=trixie
DEBIAN_VERSION_FULL=13.6
ID=debian
Xxxxxxxxxxxxx $ uname -a
Linux mypi 6.18.34+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.18.34-1+rpt1 (2026-06-09) aarch64 GNU/Linux
Info about pironman5.service
Xxxxxxxxxxxxx $ sudo systemctl status pironman5.service
* pironman5.service - pironman5 service
Active: active (running) since Tue 2026-07-14 16:34:56 CDT; 58s ago
Invocation: 168a904d19954aa89b7e37bdca9d0b6e
Main PID: 46121 (pironman5)
Tasks: 10 (limit: 9626)
CPU: 3.735s
CGroup: /system.slice/pironman5.service
|-46121 /opt/pironman5/venv/bin/python3 /usr/local/bin/pironman5 start
`-46178 /usr/bin/dbus-daemon --syslog --fork --print-pid 4 --print-address 6 --session
Jul 14 16:35:52 mlkraspberrypi pironman5[46121]: [ERROR] Failed to connect to InfluxDB: HTTPConnectionPool(host=‘localhost’, port=8086): Max retries exceeded with url: /ping (Cause>
Jul 14 16:35:52 mlkraspberrypi pironman5[46121]: [ERROR] Database is not ready
Jul 14 16:35:52 mlkraspberrypi pironman5[46121]: [ERROR] Failed to set data: Database is not ready
Jul 14 16:35:53 mlkraspberrypi pironman5[46121]: [ERROR] Failed to connect to InfluxDB: HTTPConnectionPool(host=‘localhost’, port=8086): Max retries exceeded with url: /ping (Cause>
Jul 14 16:35:53 mlkraspberrypi pironman5[46121]: [ERROR] Database is not ready
Jul 14 16:35:53 mlkraspberrypi pironman5[46121]: [ERROR] Failed to set data: Database is not ready
Jul 14 16:35:54 mlkraspberrypi pironman5[46121]: [ERROR] Failed to connect to InfluxDB: HTTPConnectionPool(host=‘localhost’, port=8086): Max retries exceeded with url: /ping (Cause>
Jul 14 16:35:54 mlkraspberrypi pironman5[46121]: [ERROR] Database is not ready
lines 1-21/21 (END)
The command executed to install drivers
curl -sSL “https://raw.githubusercontent.com/sunfounder/pironman5/v1/install.sh” | sudo bash -s – —pipower5
Pironman 5
Pironman 5 Max
Pironman 5 Pro Max
Pironman 5 Mini
Enter number [1-4]: 1
Pironman 5 v1.3.18
Branch: 1.3.x
Source: GitHub
pm_auto v2 (v2.0.5)
pm_dashboard v2 (v2.0.3)
sf_rpi_status main (v1.1.8)
pipower5 v2 (v2.1.3)
Using GitHub repositories
Install build dependencies
✓ Update package list
✓ Install build dependencies
Clone pironman5 repository
✓ Remove existing pironman5 directory
✓ Clone pironman5
✓ Set repo ownership
Run pre-install scripts
✓ Run fix_kali_gpio_spi.sh
✓ Run install_influxdb.sh
✓ Run install_lgpio.sh
✓ Run umbrel_patch.sh
Install APT dependencies
✓ Install APT dependencies
Setup system user
✓ Create pironman5 group
✓ Create pironman5 user
✓ Add myuser to pironman5 group
Setup sudo permissions
✓ Create sudoers file
✓ Set sudoers permissions
Add myuser to groups
✓ Setup gpio group
✓ Setup i2c group
✓ Setup influxdb group
✓ Setup input group
✓ Setup pipower5 group
✓ Setup spi group
✓ Setup video group
Create working directory
✓ Create directories
✓ Create log file
✓ Set work directory permissions
✓ Set work directory owner
✓ Set log directory permissions
✓ Set log directory owner
✓ Set log file permissions
✓ Set log file owner
✓ Remove old virtual environment
✓ Create virtual environment
Remove conflicting packages
✓ Uninstall RPi.GPIO
Install Python dependencies
✓ Install Python packages
Install Python packages from source
✓ Install pironman5
✓ Install pm_auto
✓ Install sf_rpi_status
✓ Install pm_dashboard
Clone PiPower5 source
✓ Clone PiPower5 source
Install PiPower5 build dependencies
✓ Install DKMS
✗ Install kernel headers
Build and install PiPower5 kernel driver
✓ Build and install pipower5.ko
Install PiPower5 Python package
✓ Install pipower5
✓ Create pipower5 symlink
Setup PiPower5 udev rules
✓ Copy udev rules
✓ Reload udev
Copy PiPower5 email templates
✓ Create email template dir
✓ Copy email templates
Create symlinks
✓ Create pironman5 symlink
Setup shell completion
✓ Install argcomplete
✓ Register bash completion
Setup auto-start
✓ Install service file
✓ Enable pironman5 service
✓ Reload systemd
Configure kernel modules
✓ Add module i2c-dev
Copy device tree overlays
✓ Copy sunfounder-pironman5.dtbo
✓ Copy PiPower5 device tree overlay
Persist device tree overlays
✓ Create persistent overlay directory
✓ Persist sunfounder-pironman5.dtbo
✓ Persist PiPower5 device tree overlay
Install kernel postinst hook
✓ Create postinst.d directory
✓ Install kernel postinst hook
✓ Run postinst hook now for existing overlay dirs
Run post-install scripts
✓ Migrate RPi.GPIO to rpi.lgpio
Finalize permissions
✓ Set execution permission on work dir
✓ Set final ownership
Write product variant
✓ Ensure work directory exists
✓ Write variant identifier
✓ Write custom module
Configure device tree overlays
✓ Add dtoverlay=sunfounder-pironman5 to config.txt
✓ Add dtoverlay=sunfounder-pipower5 to config.txt
Error happened:
Reading package lists…
Building dependency tree…
Reading state information…
E: Unable to locate package linux-headers-raspi
Please check /tmp/install.log for more details.
Sorry for the all the logs.
Anyone else having these issues?
Thanks in advance.
