Pironman 5 Max not working
Installation was working well everything was ok work perfectly and open this morning no light and ventilator
Start the commands
With dmesg just a part of mesage log
[ 1194.631606] pipower5 1-005c: Failed to read byte from register 0x9a: -121
[ 1194.655595] pipower5 1-005c: Failed to read byte from register 0x9a: -121
[ 1194.679593] pipower5 1-005c: Failed to read byte from register 0x9a: -121
[ 1194.703592] pipower5 1-005c: Failed to read byte from register 0x9a: -121
[ 1194.727591] pipower5 1-005c: Failed to read byte from register 0x9a: -121
[ 1194.751592] pipower5 1-005c: Failed to read byte from register 0x9a: -121
[ 1194.775685] pipower5 1-005c: Failed to read byte from register 0x9a: -121
[ 1194.799591] pipower5 1-005c: Failed to read byte from register 0x9a: -121
[ 1194.823601] pipower5 1-005c: Failed to read byte from register 0x9a: -121
$ sudo systemctl status pironman5.service
× pironman5.service - pironman5 service
Active: failed (Result: exit-code) since Wed 2026-07-29 09:57:00 CEST; 10min ago
Duration: 1.070s
Process: 3028 ExecStart=/usr/local/bin/pironman5 start (code=exited, status=1/FAILURE)
Main PID: 3028 (code=exited, status=1/FAILURE)
CPU: 715ms
Jul 29 09:57:00 lvghome.freeboxos.fr pironman5[3028]: return lgpio.gpiochip_open(int(dev.name[-1]))
Jul 29 09:57:00 lvghome.freeboxos.fr pironman5[3028]: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Jul 29 09:57:00 lvghome.freeboxos.fr pironman5[3028]: File “/usr/lib/python3/dist-packages/lgpio.py”, line 645, in gpiochip_open
Jul 29 09:57:00 lvghome.freeboxos.fr pironman5[3028]: return _u2i(handle)
Jul 29 09:57:00 lvghome.freeboxos.fr pironman5[3028]: File “/usr/lib/python3/dist-packages/lgpio.py”, line 458, in _u2i
Jul 29 09:57:00 lvghome.freeboxos.fr pironman5[3028]: raise error(error_text(v))
Jul 29 09:57:00 lvghome.freeboxos.fr pironman5[3028]: lgpio.error: ‘can not open gpiochip’
Jul 29 09:57:00 lvghome.freeboxos.fr systemd[1]: pironman5.service: Main process exited, code=exited, status=1/FAILURE
Jul 29 09:57:00 lvghome.freeboxos.fr systemd[1]: pironman5.service: Failed with result ‘exit-code’.
In raspi-config interface I2C is enable
Thanks for return
Regards
It looks like the system is not detecting the PiPower 5. Have you removed it from your setup?
(The PiPower 5 is this external UPS module that connects to the GPIO header on the side of the Pironman 5 case: PiPower 5 Raspberry Pi 5/4B/3B+/Zero 2 W UPS HAT, 5V/5A Power Supply, Safe Shutdown, Smart Alerts&Monitoring, USB-C PD 45W, Smart Power Management for NAS, Server, Home Assistant | SunFounder)
If it is still connected, please check the connection and reboot.
Hi
I didn’t had a pipower 5 connected
Only the pi5 inside the pironman 5 Max
I did a update upgrade from system today morning.
uname -a
Linux lvghome.freeboxos.fr 6.12.96+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.12.96-1+rpt1 (2026-07-24) aarch64 GNU/Linux
I was reading something on the forum and adding this command execution
jm1704@lvghome:~ $ sudo systemctl stop pironman5
jm1704@lvghome:~ $ sudo pironman5 start
[INFO]
[INFO] ############################################################
[INFO] Pironman5 Start
[INFO] Pironman5 version: 1.3.18
[INFO] Variant: Pironman 5 Max V2
[INFO] Config:
[INFO] {
[INFO] “system”: {
[INFO] “data_interval”: 1,
[INFO] “database_retention_days”: 30,
[INFO] “temperature_unit”: “C”,
[INFO] “enable_history”: true,
[INFO] “oled_enable”: true,
[INFO] “oled_rotation”: 0,
[INFO] “oled_sleep_timeout”: 0,
[INFO] “oled_pages”: [“mix”, “battery”, “input”, “rpi_power”],
[INFO] “rgb_enable”: true,
[INFO] “rgb_color”: “#0a1aff”,
[INFO] “rgb_brightness”: 100,
[INFO] “rgb_style”: “breathing”,
[INFO] “rgb_speed”: 50,
[INFO] “rgb_led_count”: 4,
[INFO] “rgb_led_count_min”: 4,
[INFO] “gpio_fan_pin”: 6,
[INFO] “gpio_fan_mode”: 1,
[INFO] “gpio_fan_led”: “follow”,
[INFO] “gpio_fan_led_pin”: 5,
[INFO] “shutdown_percentage”: 10,
[INFO] “send_email_on”: [“low_battery”, “power_disconnected”, “power_restored”, “power_insufficient”, “battery_critical_shutdown”, “battery_voltage_critical_shutdown”],
[INFO] “send_email_to”: “”,
[INFO] “smtp_email”: “”,
[INFO] “smtp_password”: “”,
[INFO] “smtp_server”: “”,
[INFO] “smtp_port”: 465,
[INFO] “smtp_security”: “ssl”,
[INFO] “pipower5_buzzer_volume”: 5,
[INFO] “pipower5_buzz_on”: [“battery_activated”, “low_battery”, “power_disconnected”, “power_restored”, “power_insufficient”, “battery_critical_shutdown”, “battery_voltage_critical_shutdown”],
[INFO] “pipower5_buzz_sequence”: {“battery_activated”: [[“A4”, 200], [“pause”, 100], [“B4”, 200]], “low_battery”: [[“A4”, 250], [“pause”, 150], [“A4”, 250]], “power_disconnected”: [[“D5”, 150], [“G4”, 150]], “power_restored”: [[“G4”, 150], [“D5”, 150]], “power_insufficient”: [[“B4”, 200], [“pause”, 100], [“B4”, 200], [“pause”, 100], [“B4”, 300]], “battery_critical_shutdown”: [[“C6”, 120], [“pause”, 60], [“C6”, 120], [“pause”, 60], [“C6”, 400]], “battery_voltage_critical_shutdown”: [[“C6”, 120], [“pause”, 60], [“C6”, 120], [“pause”, 60], [“C6”, 400], [“pause”, 60], [“C6”, 400]]},
[INFO] “debug_level”: “INFO”
[INFO] }
[INFO] }
[INFO] Device info:
[INFO] {
[INFO] “name”: “Pironman 5 Max”,
[INFO] “id”: “pironman5-max”,
[INFO] “peripherals”: [
[INFO] “input_voltage”,
[INFO] “output_power”,
[INFO] “delete_log_file”,
[INFO] “restart_service”,
[INFO] “gpio_fan_led”,
[INFO] “oled_page_ips”,
[INFO] “cpu_temperature”,
[INFO] “shutdown”,
[INFO] “pipower5_buzz_on”,
[INFO] “oled_sleep”,
[INFO] “oled_page_mix”,
[INFO] “storage”,
[INFO] “output_voltage”,
[INFO] “shutdown_percentage”,
[INFO] “temperature_unit”,
[INFO] “gpio_fan_mode”,
[INFO] “pwm_fan_speed”,
[INFO] “ws2812”,
[INFO] “pipower5”,
[INFO] “oled_page_performance”,
[INFO] “battery_percentage”,
[INFO] “battery_current”,
[INFO] “power-failure-simulation”,
[INFO] “ip_address”,
[INFO] “gpio_fan_state”,
[INFO] “gpu_temperature”,
[INFO] “oled_page_rpi_power”,
[INFO] “data_interval”,
[INFO] “network”,
[INFO] “history”,
[INFO] “oled_page_input”,
[INFO] “pipower5_buzzer_volume”,
[INFO] “pi5_power_button”,
[INFO] “power_source”,
[INFO] “log”,
[INFO] “pipower5_buzzer”,
[INFO] “reboot”,
[INFO] “clear_history”,
[INFO] “memory”,
[INFO] “input_current”,
[INFO] “output_current”,
[INFO] “battery_voltage”,
[INFO] “default_on”,
[INFO] “is_charging”,
[INFO] “cpu”,
[INFO] “oled_page_battery”,
[INFO] “oled_page_disk”,
[INFO] “send_email”,
[INFO] “mac_address”,
[INFO] “debug_level”,
[INFO] “oled”,
[INFO] “is_input_plugged_in”
[INFO] ],
[INFO] “version”: “1.3.18”,
[INFO] “app_name”: “pironman5”,
[INFO] “config_path”: “/opt/pironman5/config.json”
[INFO] }
[INFO] PM_Auto version: 2.0.5
[INFO] PM_Dashboard version: 2.0.3
File “/usr/local/bin/pironman5”, line 6, in
sys.exit(_cli.main())
File “/opt/pironman5/venv/lib/python3.11/site-packages/pironman5/_cli.py”, line 872, in main
pironman5 = Pironman5(config_path=config_path)
File “/opt/pironman5/venv/lib/python3.11/site-packages/pironman5/pironman5.py”, line 120, in init
self.pm_auto = PMAuto(self.config[‘system’],
File “/opt/pironman5/venv/lib/python3.11/site-packages/pm_auto/pm_auto.py”, line 53, in init
self.addons = Addons(
File “/opt/pironman5/venv/lib/python3.11/site-packages/pm_auto/addons/init.py”, line 59, in init
addons = get_addons(peripherals)
File “/opt/pironman5/venv/lib/python3.11/site-packages/pm_auto/addons/init.py”, line 37, in get_addons
from .ws2812 import WS2812Addon
File “/opt/pironman5/venv/lib/python3.11/site-packages/pm_auto/addons/ws2812.py”, line 6, in
import board
File “/opt/pironman5/venv/lib/python3.11/site-packages/board.py”, line 45, in
from adafruit_blinka.board.raspberrypi.raspi_5 import *
File “/opt/pironman5/venv/lib/python3.11/site-packages/adafruit_blinka/board/raspberrypi/raspi_5.py”, line 6, in
from adafruit_blinka.microcontroller.bcm2712 import pin
File “/opt/pironman5/venv/lib/python3.11/site-packages/adafruit_blinka/microcontroller/bcm2712/pin.py”, line 7, in
from adafruit_blinka.microcontroller.generic_linux.lgpio_pin import Pin
File “/opt/pironman5/venv/lib/python3.11/site-packages/adafruit_blinka/microcontroller/generic_linux/lgpio_pin.py”, line 31, in
CHIP = _get_gpiochip()
File “/opt/pironman5/venv/lib/python3.11/site-packages/adafruit_blinka/microcontroller/generic_linux/lgpio_pin.py”, line 26, in _get_gpiochip
return _u2i(handle)
It looks like you may have installed the PiPower 5 version of the Pironman 5 software. Please try reinstalling the standard version by running the following command:
curl -sSL "https://raw.githubusercontent.com/sunfounder/pironman5/v1/install.sh" | sudo bash
Hi
I did a clean of what i can do removing completly pironman5 and pipower5 directories
Réinstall the pironman5 without pipower and the problem was still the same but less messages.
And i tried the command rpi-update to put the firmware update .
did a reboot and when pi5 was up the light was there as before.
Now everything ok
Thanks
Thank you – we wish you all the best too! :blush:
If you run into any further issues with your Pironman 5 Max, please don’t hesitate to reach out. We’re here to help.
