function: Increment a number every second on the 4-digit 7-segment display.
// Email:service@sunfounder.com
// Website:www.sunfounder.com
// Define the pins that are connected to the segments and the digits of the 7-segment display
int segmentPins[] = {2, 3, 4, 5, 6, 7, 8, 9};
int digitPins[] = {13, 12, 11, 10};
long n = 0; // Variable to store the current stopwatch number
int del = 5; // Delay time (in milliseconds) to keep each digit illuminated
unsigned long previousMillis = 0; // Store the last time the stopwatch incremented
const long interval = 300; // One-second interval (in milliseconds)
// Numbers 0-9 for a 7-segment display (common-cathode)
byte numbers[10][8] = {
{HIGH, HIGH, HIGH, HIGH, HIGH, HIGH, LOW, LOW}, // 0
{LOW, HIGH, HIGH, LOW, LOW, LOW, LOW, LOW}, // 1
{HIGH, HIGH, LOW, HIGH, HIGH, LOW, HIGH, LOW}, // 2
{HIGH, HIGH, HIGH, HIGH, LOW, LOW, HIGH, LOW}, // 3
{LOW, HIGH, HIGH, LOW, LOW, HIGH, HIGH, LOW}, // 4
{HIGH, LOW, HIGH, HIGH, LOW, HIGH, HIGH, LOW}, // 5
{HIGH, LOW, HIGH, HIGH, HIGH, HIGH, HIGH, LOW}, // 6
{HIGH, HIGH, HIGH, LOW, LOW, LOW, LOW, LOW}, // 7
{HIGH, HIGH, HIGH, HIGH, HIGH, HIGH, HIGH, LOW}, // 8
{HIGH, HIGH, HIGH, HIGH, LOW, HIGH, HIGH, LOW} // 9
// Configure all segment and digit pins as OUTPUT
for (int i = 0; i < 8; i++) {
pinMode(segmentPins[i], OUTPUT);
for (int i = 0; i < 4; i++) {
pinMode(digitPins[i], OUTPUT);
digitalWrite(digitPins[i], HIGH); // Initially turn off all digits (for common-cathode displays, HIGH is OFF)
void loop() {
// Check if a second has passed since the last increment
if (millis() - previousMillis >= interval) {
previousMillis += interval; // Update the last increment time
n = (n + 1) % 10000; // Increment the stopwatch number and wrap around at 9999
displayNumber(n); // Display the current stopwatch number on the 7-segment display
// Function to display a 4-digit number on the 7-segment display
void displayNumber(long num) {
int divisor = 1000; // Start with the highest divisor for the first digit
for (int digit = 0; digit < 4; digit++) {
clearLEDs(); // Turn off all segments and digits
pickDigit(digit); // Activate the current digit
int value = (num / divisor) % 10; // Extract the specific digit from the number
pickNumber(value); // Illuminate the segments to display the digit
divisor /= 10; // Reduce the divisor for the next digit
delay(del); // Keep the digit illuminated for a short time
// Function to activate a specific digit (0 to 3)
void pickDigit(int x) {
digitalWrite(digitPins[x], LOW); // Turn ON the selected digit (for common-cathode displays, LOW is ON)
// Function to display a single number (0-9) on the currently activated digit
void pickNumber(int x) {
digitalWrite(segmentPins[i], numbers[x][i]); // Set each segment according to the pattern for the given number
// Function to turn off all segments and digits
void clearLEDs() {
digitalWrite(segmentPins[i], LOW); // Turn off all segments
digitalWrite(digitPins[i], HIGH); // Turn off all digits
Please try running it with this code.
