I have the Euler-Kit, and I set up the “Display The Level” project.
When I run 2.2_display_the_level.py, bars 5 and 10 do not display.
In the shell, I run this command:
machine.Pin(10).toggle()
And the sixth LED lights instead of the fifth as I would have expected.
If I manually iterate over pins 6 - 15, toggling them on and off myself, I learn that LEDs 5 and 10 do not light at all, and pins 14 and 15 do not seem to toggle anything.
Is this by design? It feels purposeful, as if LEDs 5 and 10 are meant to be turned on through some other mechanism, but I don’t see anything to suggest what is meant to happen here.
This seems to be a simple wrong connection or a little bad contact of the line. Please check the wiring carefully. If there is no mistake in the wiring, try to replace the GPIO10 line. If you have a multimeter or use an LED, check whether the IO10 outputs a high level normally when the level is high.
