I think I might have found an issue with the Python script for Raphael Kit 1.1.3.
After wiring the schematic (double and triple checked), when running the script, the loop seems to work backwards. When LED is supposed to be off it is on, and when it is supposed to be on, it is off.
Here is the sequence:
- Run script
- ALL LEDs on
- In sequence 1, 3, 5, 7, and 9 will turn off and back on
- In sequence 2, 4, 6, 8, and 10 will turn off and back on
- In sequence 1 - 10 will turn off and back on
The clue was in the def setup(): where it said:
Set all ledPins to high(+3.3V) to off led
The GPIO.Output is set to GPIO.output(i, GPIO.LOW) # Set all ledPins to high(+3.3V) to off led
But, another clue was referencing 1.1.1 where in its def setup() it showed this:
Set LedPin’s mode to output,and initial level to High(3.3v)
GPIO.setup(LedPin, GPIO.OUT, initial=GPIO.HIGH)
I was able to modify the script to perform as it seems it should where all LEDs start as off and they are turned on and back off in sequence. I changed all GPIO.LOW entries to GPIO.HIGH in the script and it runs as expected.
I am curious whether I was right or wrong in this.
