I have a pi4 in a pironman case running umbrel now my fan lights and oled not working
Umbrel isn’t mentioned in compatible OS list.
After installing the Umbrel system, did you also install the pironman5 software? Please install it using the following commands, and reboot after the installation is complete.
cd ~
git clone -b base https://github.com/sunfounder/pironman5.git --depth 1cd ~/pironman5
For a detailed tutorial, please refer to:https://docs.sunfounder.com/projects/pironman5/en/latest/pironman5/set_up/set_up_umbrel.html
He have a Pi4, not a Pi5…
@Weirdyguy – You’re absolutely right, we hadn’t noticed that. Thank you for pointing it out.
@Harley751 – The older version of Pironman is not compatible with the Umbrel system, which is why the fan and OLED screen are not working.
