I recently purchased and built the PICAR-V, and I have everything working. However, I want to change the code and do testing using a wired power cable. I power my Raspberry Pi 4b using a USB-C adapter but it the car is unable to move the servos or motors in this mode. The camera does work though.
The instructions on the remote_control page say “You are also recommended to use the power adapter of Raspberry Pi to power your car for that the first test will take a long time.” so I assumed this worked, but it isn’t working for me.
Can someone confirm what the problem could be, why the car doesn’t get powered even though the raspberry pi is, and how I could fix this?
Thank you.
