I assembled the Picar-X exactly according to instructions with Raspberrypi 4. All of the examples work fine except the camera.
I checked the FCC cable on both ends and they are perfectly in place.
Console logs:
$ libcamera-hello --list-cameras
No cameras available!
$ libcamera-hello
MoTTY X11 proxy: unable to connect to forwarded X server: Network error: Software caused connection abort
Preview window unavailable
[0:12:33.134249754] [2250] INFO Camera camera_manager.cpp:297 libcamera v0.0.5+83-bde9b04f
~/picar-x/example $ sudo python3 7.display.py
vilib 0.2.1 launching …
picamera2 0.3.12
imshow start …
Input key to call the function!
q: Take photo
1: Color detect : red
2: Color detect : orange
3: Color detect : yellow
4: Color detect : green
5: Color detect : blue
6: Color detect : purple
0: Switch off Color detect
r: Scan the QR code
f: Switch ON/OFF face detect
s: Display detected object information
Camera(s) not found (Do not forget to disable legacy camera with raspi-config).
Camera init sequence did not complete.
Exception in thread camera_satrt:
File “/usr/lib/python3/dist-packages/picamera2/picamera2.py”, line 242, in init
self._open_camera()
File “/usr/lib/python3/dist-packages/picamera2/picamera2.py”, line 442, in _open_camera
if not self._initialize_camera():
File “/usr/lib/python3/dist-packages/picamera2/picamera2.py”, line 406, in _initialize_camera
raise RuntimeError(“Camera(s) not found (Do not forget to disable legacy camera with raspi-config).”)
RuntimeError: Camera(s) not found (Do not forget to disable legacy camera with raspi-config).
File “/usr/lib/python3.9/threading.py”, line 954, in _bootstrap_inner
self.run()
File “/usr/lib/python3.9/threading.py”, line 892, in run
self._target(*self._args, **self._kwargs)
File “/usr/local/lib/python3.9/dist-packages/vilib-0.2.1-py3.9.egg/vilib/vilib.py”, line 643, in camera_clone
Vilib.camera()
File “/usr/local/lib/python3.9/dist-packages/vilib-0.2.1-py3.9.egg/vilib/vilib.py”, line 650, in camera
picam2 = Picamera2()
File “/usr/lib/python3/dist-packages/picamera2/picamera2.py”, line 254, in init
raise RuntimeError(“Camera init sequence did not complete.”)
RuntimeError: Camera init sequence did not complete.
It looks that the camera is not being detected at all.
UPDATE:
I am able to take a picture using this command:
