After zeroing and calibrating the servos on my Picar-x with Raspberry Pi 4, I tested its movement with the 2.move.py script. The script ran perfectly with all the expected movements. Upon running this script a second time, however, all 3 servos jerked abruptly prior to executing the expected movements. This occurred on all subsequent runs of this script until the system was rebooted. After reboot, the 2.move.py script again ran perfectly on its first run with no jerking. How do I fix this problem?
We haven’t been able to reproduce the issue on our side.
Could you please record a short video showing the jerking motion so we can see exactly what is happening? I suspect it may be caused by something outside the code itself.
Please upload the video to a cloud service (Google Drive, OneDrive, Dropbox) and share the link with us – make sure to grant access.
Once we see the video, we will be able to advise further.
The video shows that the initial jerking is better described as a judder. It occurs on all runs of 2.move.py after the Raspberry Pi is rebooted via software. The only time is does not occur is on the first run after the Robot Hat is powered on.
The video also shows that pressing the zero button on the Robot hat caused the servos to make two movements. Is that normal and which position is zero.
Thanks for your help.
During zero calibration: The double-jerk motion you see is actually intentional. The first movement is a “performance action” designed to visually confirm that the calibration has taken effect. The second movement is the one that sets the correct angle. This is normal behavior and not a defect.
Regarding the jerk when running the code a second time: We are currently looking into this issue, but we have not been able to reproduce it on our test units. Please rest assured that this does not cause any damage to the robot, and you can continue using your PiCar-X without concern.
The video below shows the judder in slow motion. It occurs whenever the picarx library is initialized (e.g. px=picarx() ), except on the first run after the Robot Hat is powered on via its on/off switch.
Thank you for the follow-up. While reviewing, we found an important detail in the Picarx library source: every time px = picarx() initializes, the library already resets the Robot HAT’s MCU automatically. Could you please run one more direct comparison test to confirm whether a hardware reset clears the judder:
- Keep the Robot HAT powered on (do not switch it off).
- Press the RST button on the Robot HAT once.
- Then run
px = picarx()and see whether the judder is still there.
If the judder is gone after pressing RST, it means the library’s built-in reset is not fully clearing the previous state, and we can improve the initialization to fix it at the source. If it still judders after pressing RST, we will look into the hardware/power path. Please share the result with us — thank you!
I ran the test you suggested and pressing the RST button does not eliminate the judder. I ran the test multiple times and the result was the same.
We would like to send you a replacement Robot HAT that has been pre-tested to ensure it works properly. We hope this will address the issue.
To proceed, please contact us directly at service@sunfounder.com with the following information:
Your shipping address (including recipient name, street address, city, state/province, postal code, and country)
Your phone number (required by the courier)
Your original order number if available
Once we receive these details, we will arrange to dispatch the replacement Robot HAT to you as soon as possible.
We apologize for the inconvenience and appreciate your patience.
I received and installed the replacement Robot Hat today, but nothing has changed. When running the 2.move.py script, the judder occurs on every run, except the first run after the Robot Hat is powered on via it’s off/off switch. Rebooting the OS while maintaining power to the Robot Hat does not eliminate the judder, nor does pushing the RST button.
Do you have any other ideas for eliminating the judder? Is the problem with the Raspberry Pi itself? If so, I need to know soon because my window to return the Raspberry Pi ends on September 8, 2026.
Thanks for all your help!
We have tested the issue you reported. Based on our current findings, the behavior may be related to the servos, as some units may experience slight jitter when the Picar-X library initializes.
To help resolve the issue and confirm the cause, we would be happy to send you a replacement set of servos. Once received, please install them and test again. If the issue persists, please feel free to let us know.
I replaced the 3 white servos with the 3 black servos you sent me. I then zeroed and recalibrated the new servos. I then ran the 2.move.py script multiple times and the judder has been completely eliminated.
Thank-you for all your help resolving this issue
Thank you for your patience throughout this process, and for sharing the final test result with us — it was very helpful.
We’re glad to hear the issue has been fully resolved. Based on your feedback, after replacing the 3 white servos with the 3 black servos and recalibrating them, the judder is completely gone. This matches our earlier assessment: the judder came from individual differences between servos, as some units may experience slight jitter when the PiCar-X library initializes, rather than from the Robot HAT or the code itself.
Thank you again for your patience and cooperation, and we apologize that this took some extra time. If you have any further questions while using it, please feel free to contact us.
