Picar-x with ezblock image and added graphical desktop and python code
I downloaded and installed the ezblock raspberry pi image, which worked. Then installed LXDE desktop environment, which worked. Then tried to install the python code, which broke the build. I got the following error:
Reading package lists…
Building dependency tree…
Reading state information…
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
** libttspico0 : Depends: libc6 (>= 2.29) but 2.28-10+rpt2+rpi1+deb10u2 is to be installed**
E: Unable to correct problems, you have held broken packages.
I’m not sure how to fix this?
I have a question, is there an image that has the ezblock software with a raspberry pi graphical desktop environment and the python code running on the same image?
Sorry we did not create an ezblock image with a desktop.
If you want to use Python code to control picar-x, we recommend that you use the Raspberry Pi system and install all of our library code on the system.
If you want to use the ezblock APP to control picar-x, we suggest that you install the ezblock OS image we provided (without a desktop).
So you will need to prepare two SD cards - one specifically for Python control, and the other for ezblock APP control.
Thank you for your response.
