EZBlock - do I need different OS
I have built the PICAR-X and everthing works fine with Python. I tried to connect with EZBLOCK and it will not connect. Do I need a different OS build on the Raspberry 3B+? Can I use one OS build for both Python and EZBLOCK?
Thank you
I figured it out in case this might help another new user. You do need a different Raspberry OS build which contains the EZBlock build to use the EZBlock program. My first OS build was for Python only. I will keep two micro SD cards one for each.
