Is the Pipower 5 compatible with the FREENOVE Raspberry Pi 5 Case Kit Pro?
The PiPower 5 is not officially compatible with the FREENOVE Raspberry Pi 5 Case Kit Pro. Furthermore, due to potential physical interference, using them together may cause issues.
If you already own both products, you are welcome to try assembling them yourself. However, please do not expect them to work together seamlessly, as they were not designed to be compatible.
Thank you. I was asking prior to purchasing the Freenove case to avoid any issues.
