I have extensively tested compatibility between the Freenove FNK0107 “Freenove Raspberry Pi 5 NAS Case Kit, Quad M.2 NVMe SSD Slots, 5 PWM ARGB Fans Light Sync, CPU Tower Cooler, 4.3” Touchscreen, Stereo Speakers, 3.5 mm Audio" case and the following SunFounder HAT+s:
PiPower 5 HAT+ (No PiPower 5 OLED data output, though the Freenove OLED data output works fine.)
Thank you for sharing your test results – this is very helpful. If other users have similar questions about compatibility, we will refer them to your findings.
Regarding the OLED on the Freenove case displaying PiPower 5 data: the PiPower 5 uses the u‑power driver, which is not integrated with the Freenove case’s OLED driver. Since this is specific to Freenove’s software, we are unable to modify it on our side. Freenove would need to add support for this, or you could modify the code yourself.
