I have both the AI Fusion HAT+ and the PiPower 5 HAT+
I would like to use them together, but each one specifically states that the power must be plugged into it.
Is it possible to use these two HAT+ together? If so, which one gets the power connection?
In theory, these two HAT+ units can be used together.
You can:
Connect a battery to the PiPower 5
Then use a USB‑A to USB‑C cable to power the Fusion HAT+
However, you must pay attention to the power‑up sequence:
First, press the power button on the PiPower 5 to supply power to the Fusion HAT+.
Then press the power button on the Fusion HAT+ to power on the Raspberry Pi.
That said, using them together in this way doesn’t really offer much practical benefit.
Since the Fusion HAT+ already has built‑in UPS (Uninterruptible Power Supply) capability, there is generally no need to add a PiPower 5 to power the system.
Thank you for the clarification!
