Using RPI-5 4g flashed with latest AI fusion image. The Pi booted and worked before adding the Hat. Initially the Hat powered-on and charged, the LEDs indicating the charge was complete. After connecting the camera assembly, and some power-on/off cycles, the Hat fails to power-on or boot, no LEDs when connected to power and powered-on. The Pi alone continues to boot when disconnected from the Hat. Please help thank you
Based on the symptoms you described:
The Raspberry Pi 5 works fine when used alone
It cannot power on when the Fusion HAT is connected
The LED indicators on the Fusion HAT do not light up at all
This suggests that the Raspberry Pi itself is likely working normally, but there appears to be a power issue or short circuit on the Fusion HAT side.
Please completely remove the Fusion HAT from the Raspberry Pi first, and then perform the following tests separately:
1. Connect only the battery and press the power button on the Fusion HAT
Observe:
Does the green power LED light up?
Do the yellow battery level LEDs light up?
2. Power the Fusion HAT alone using a Type-C cable
Observe:
Does the charging LED light up?
Do the battery level LEDs display normally?
Also, please send us:
A photo of the board
Photos showing the LED status
Or a short video of the power-on test,please pload the video to Google Drive or OneDrive and share the link.
This will help us analyze the issue further.
Thank you for your patience and cooperation.
Thank you. I followed your suggested steps and still no power-on. Apparently limited to 1 photo attached which shows Hat only after attempted power-on connected to batt. Couple additional details:
Using the kit as part of the McWhorter tutorial, includes THRML Fan
Battery multimeter test on it’s own shows > 7v
Please contact our support team at service@sunfounder.com with your original order number and shipping address. We will arrange to send you a replacement Fusion HAT that has been fully tested before shipping.
I have a similar sounding problem - my Pi 5 refuses to power up when connected to my AI Fusion HAT+ - see picture - Pi5 power showing red.
From the photos, the LEDs on the Fusion HAT all look normal and the battery is charged, but the Raspberry Pi 5 is showing a red power LED. We also noticed that there does not appear to be a Micro SD card inserted in the Raspberry Pi 5. Without a system card, the Raspberry Pi 5 cannot boot normally, and a steady red power LED is expected in that case — so this is very likely the direct cause of the “not powering on” symptom.
Could you please try the following:
Prepare a Micro SD card and flash the official AI Fusion OS image (the same image you used before) using Raspberry Pi Imager.
Insert the card into the Micro SD slot on the underside of the Raspberry Pi 5, making sure it is fully seated (you should feel a slight spring/click as it locks in).
With the HAT and battery still connected, power the unit on again and check whether the Raspberry Pi 5 boots normally and whether the green ACT LED shows card activity.
If it boots normally with the system card inserted, the hardware is fine and you can continue with the software setup.
If it still shows a red LED and does not boot after inserting the card, please let us know and also provide the following so we can investigate further:
The result of trying another known-good system card, or re-flashing the image;
The result of removing the HAT completely and booting the Raspberry Pi 5 alone with the official power supply;
Clear photos of the front and back of the HAT, plus a photo or short video of the LED status when powered on (please upload them to Google Drive or a similar cloud service, set the link permission to “anyone with the link can view”, and send us the link).
We would also like to confirm one thing: you mentioned earlier that the Raspberry Pi 5 works fine on its own — was a system card inserted when you tested that? This will help us narrow down the issue.
Thank you for your patience and cooperation. We look forward to your test results.
