I have rolled back to the prior version of the add-on and it still is experiencing the error. I found a post in the Addon GitHub repo noting an error corresponding to the latest Home Assistant OS / Core update 14.0
I am going to try reverting to prior OS version to try to resolve.
Home Assistant OS14.0 is a just updated version and is having compatibility issues.
So we recommend you to install pironman5 plugin with OS13 version first.
We are testing the compatibility between Home Assistant OS14.and pironman5.
Hello! how about now? I am on HA 14.1 and i really do not want to downgrade my entire system for full compatibility. Have the plugins been tested and fixed yet?
EDIT: i rebooted 3 or 4 times and the I2C and SPI keep having the ‘configured on, but not yet enabled. try rebooting’ message. there must be something wrong with this part of the script. please help
Currently HA 14.1 is compatible with pironman5.
When you install the Pi Config Wizard plug-in successfully, set up the configuration of I2C and SPI, after the first time to enable I2C and SPI, reboot the system, and then go to the Pi Config Wizard plug-in to check the status, there will be a hint that it has been configured, but not yet enabled. If you reboot the system again, I2C and SPI will be enabled successfully, and you can go to install the pironman5 plugin.
If you have problems, we suggest you provide us with screenshots or videos to help us analyze and solve the problem.
