Pironman on Home Assistant OS 15.2
Due to support of the supervised version being deprecated, I recently migrated to full Home Assistant OS. I went back through the same instructions to configure my Pironman and it seems to be mostly working. OLED is working fine, the fan is working fine and follows the RGB style as well as the set temperature. The only issue is the RBG strip never lights up. This was all working when I had it configured with Raspberry Pi OS. Logs don’t show any errors. Tested with an additional power supply as well.
Logs:
Add-on: Pironman
Pironman support
Add-on version: 1.0.12
System: Home Assistant OS 15.2 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2025.6.1
Home Assistant Supervisor: 2025.05.5
[10:48:41] INFO: Configuring timezone (America/Denver)…
temperature_unit: F
fan_temp: 90
display_always_on: true
display_on_for: 30
rgb_on: true
rgb_style: breath
rgb_color: FF0000
rgb_speed: 50
rgb_freq: 1000
rgb_pin: 10
set temperature unit to F
set the fan on temperature to 90
set screen_always_on to on
set screen_off_time to 30
set rgb_enable to on
set rgb_style to breath
set rgb_color to FF0000
set rgb_blink_speed to 50
set rgb_pwm_freq to 1000
set rgb io to pin 10 (spi)
restarting pironman
stopping pironman
pid=264
run in foreground
25/06/19 10:48:43,912 [DEBUG] Home Assistant Addon mode
------------------------25/06/19 10:48:43------------------------
pironman version: 2.2.6
username:
Kernel Version:
Linux 6fa7f6d2-pironman 6.6.74-haos-raspi #1 SMP PREEMPT Mon Apr 14 16:32:39 UTC 2025 aarch64 aarch64 aarch64 GNU/Linux
PCB info:
Revision : d03115
25/06/19 10:48:43,933 [DEBUG] power_key_pin : 16
25/06/19 10:48:43,933 [DEBUG] fan_pin : 6
25/06/19 10:48:43,933 [DEBUG] update_frequency : 0.5
25/06/19 10:48:43,933 [DEBUG] temp_unit : F
25/06/19 10:48:43,933 [DEBUG] fan_temp : 90.0
25/06/19 10:48:43,933 [DEBUG] screen_always_on : True
25/06/19 10:48:43,934 [DEBUG] screen_off_time : 30
25/06/19 10:48:43,934 [DEBUG] rgb_enable : True
25/06/19 10:48:43,934 [DEBUG] rgb_style : breath
25/06/19 10:48:43,934 [DEBUG] rgb_color : FF0000
25/06/19 10:48:43,934 [DEBUG] rgb_blink_speed : 50
25/06/19 10:48:43,934 [DEBUG] rgb_pwm_freq : 1000
25/06/19 10:48:43,935 [DEBUG] rgb_pin : 10
25/06/19 10:48:43,946 [DEBUG] rgb_strip init success
25/06/19 10:48:43,958 [DEBUG] oled init success
25/06/19 10:48:43,976 [DEBUG] rgb_show
25/06/19 10:48:43,977 [DEBUG] rgb_show: breath
25/06/19 10:48:43,995 [DEBUG] Get IP: 192.168.1.6
Config:
There may be compatibility issues between Home Assistant OS 15.2 and the Pironman component.
We recommend using an earlier version of Home Assistant OS to install the Pironman component and see how it works.
We will conduct testing and validation on Home Assistant OS 15.2 next week.
Just following up on this to see how testing and validation of Home Assistant OS 15.2 went/is going
We sincerely apologize for the inconvenience. Our team is currently investigating this issue, but we haven’t found any error logs so far. Additionally, during our testing, the RGB lights remain stuck on white and cannot be controlled or adjusted.
We will need some additional time to resolve this and expect to provide you with an update by next week.
In the meantime, we recommend installing the Pironman software on a Raspberry Pi Bookworm OS as a temporary workaround.
We have resolved the issue.
You need to add the following lines at the end of the config.txt file in the Pi Config Wizard component:
core_freq=500
core_freq_min=500
Click save and then reboot the system to resolve the RGB light issue. (See the image.)
