Pironman v2 leds and home assistant os
having issue getting leds to stay on.. fan rgb turns on and shortly after turns off. Led strip does not turn on. Led display stays on. Also no “protection mode” on 1.0.12 “latest update”
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-timezone: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-timezone successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
24/08/30 17:04:12,230 [DEBUG] Received SIGTERM or SIGINT signal. Cleaning up…
24/08/30 17:04:12,671 [DEBUG] error
24/08/30 17:04:12,672 [DEBUG] Button is closed or uninitialized
Add-on: Pironman
Pironman support
Add-on version: 1.0.12
System: Home Assistant OS 13.1 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2024.8.3
Home Assistant Supervisor: 2024.08.0
[17:04:18] INFO: Configuring timezone (America/Los_Angeles)…
temperature_unit: C
fan_temp: 50
display_always_on: true
display_on_for: 60
rgb_on: true
rgb_style: colorful
rgb_color: 0a1aff
rgb_speed: 50
rgb_freq: 500
rgb_pin: 10
set temperature unit to C
set the fan on temperature to 50
set screen_always_on to on
set screen_off_time to 60
set rgb_enable to on
set rgb_style to colorful
set rgb_color to 0a1aff
set rgb_blink_speed to 50
set rgb_pwm_freq to 500
set rgb io to pin 10 (spi)
restarting pironman
stopping pironman
pid=264
run in foreground
24/08/30 17:04:21,477 [DEBUG] Home Assistant Addon mode
------------------------24/08/30 17:04:21------------------------
pironman version: 2.2.6
username:
Kernel Version:
Linux 6fa7f6d2-pironman 6.6.31-haos-raspi #1 SMP PREEMPT Wed Aug 21 16:30:30 UTC 2024 aarch64 aarch64 aarch64 GNU/Linux
PCB info:
Revision : c03112
Model : Raspberry Pi 4 Model B Rev 1.2
24/08/30 17:04:21,498 [DEBUG] power_key_pin : 16
24/08/30 17:04:21,499 [DEBUG] fan_pin : 6
24/08/30 17:04:21,499 [DEBUG] update_frequency : 0.5
24/08/30 17:04:21,500 [DEBUG] temp_unit : C
24/08/30 17:04:21,501 [DEBUG] fan_temp : 50.0
24/08/30 17:04:21,502 [DEBUG] screen_always_on : True
24/08/30 17:04:21,502 [DEBUG] screen_off_time : 60
24/08/30 17:04:21,502 [DEBUG] rgb_enable : True
24/08/30 17:04:21,502 [DEBUG] rgb_style : colorful
24/08/30 17:04:21,502 [DEBUG] rgb_color : 0a1aff
24/08/30 17:04:21,502 [DEBUG] rgb_blink_speed : 50
24/08/30 17:04:21,503 [DEBUG] rgb_pwm_freq : 500
24/08/30 17:04:21,503 [DEBUG] rgb_pin : 10
24/08/30 17:04:21,516 [DEBUG] rgb_strip init success
24/08/30 17:04:21,530 [DEBUG] oled init success
24/08/30 17:04:21,550 [DEBUG] rgb_show
24/08/30 17:04:21,552 [DEBUG] rgb_show: colorful
Are you unable to get pironman V2 to work properly on both the Raspberry Pi system and Home Assistant OS 13.1?
Please describe the issue in detail. Which specific features are not functioning correctly?
