If i select the disks one by one in the dashboard everything is correct but when i select “total” the bar looks almost full. Any help would be appreciated.
To help us reproduce and resolve the issue effectively, could you please provide the following details:
Operating System: Which system are you currently using?
Software Version: Which version of the Pironman5 software did you install?
Log Output: Please provide the log information by running the command cat /var/log/pironman5/main.log and sharing its output.
I installed everything to and booted from the nvme, later added a sd card as extra storage and saw the visual glitch on the oled disk bar.
Below is the requested information.
(1)
PRETTY_NAME=“Debian GNU/Linux 12 (bookworm)”
NAME=“Debian GNU/Linux”
VERSION_ID=“12”
VERSION=“12 (bookworm)”
VERSION_CODENAME=bookworm
ID=debian
(2)
I downloaded the official pironman 5 software
(3)
26/02/02 12:32:16.018 [DEBUG] Config path: /opt/pironman5/venv/lib/python3.11/site-packages/pironman5/config.json
26/02/02 12:32:16.018 [DEBUG] Pironman5 version: 1.2.26
26/02/02 12:32:16.018 [DEBUG] Variant: Pironman 5
26/02/02 12:32:16.018 [DEBUG] Config: {‘system’: {‘data_interval’: 1, ‘rgb_color’: ‘#0a1aff’, ‘rgb_brightness’: 50, ‘rgb_style’: ‘rainbow’, ‘rgb_speed’: 30, ‘rgb_enable’: False, ‘rgb_led_count’: 4, ‘temperature_unit’: ‘C’, ‘oled_enable’: True, ‘oled_rotation’: 0, ‘oled_disk’: ‘total’, ‘oled_network_interface’: ‘end0’, ‘gpio_fan_pin’: 6, ‘gpio_fan_mode’: 2, ‘debug_level’: ‘INFO’}}
26/02/02 12:32:16.018 [DEBUG] Device info: {‘name’: ‘Pironman 5’, ‘id’: ‘pironman5’, ‘peripherals’: [‘storage’, ‘cpu’, ‘network’, ‘memory’, ‘history’, ‘log’, ‘ws2812’, ‘cpu_temperature’, ‘gpu_temperature’, ‘temperature_unit’, ‘oled’, ‘clear_history’, ‘delete_log_file’, ‘pwm_fan_speed’, ‘gpio_fan_state’, ‘gpio_fan_mode’], ‘version’: ‘1.2.26’, ‘app_name’: ‘pironman5’}
26/02/02 12:32:16.018 [DEBUG] PM_Auto version: 1.2.12
26/02/02 12:32:16.019 [DEBUG] PM_Dashboard version: 1.2.10
26/02/02 12:32:21.558 [INFO] PMAuto started
26/02/02 12:32:21.631 [INFO] PmDashboard started
Have you made any modifications to the code?
We performed a normal verification attempt but were unable to reproduce the issue you encountered.
The disk usage values are generally consistent with the progress bar.
If possible, we recommend that you format your SSD or SD card, reinstall the operating system, then reinstall the Pironman5 software. After restarting the system, check the disk status on the OLED again.
I did not change any code. I will explain everything clearly, here is my installation order (everything on nvme) ; pi os lite > openmediavault > pironman 5 software. I then decided to add extra storage using the sd card slot. Everything works flawlessly. If i select the nvme or the sd card separately in pironman 5 dashboard they look as they should. Only when i select the “total” option there seems to be a visual glitch.
Could it be that the problem occurred after installing and configuring OpenMediaVault?
After installing the system, please try installing the Pironman5 software directly to see how it works.
