would the Raspberry Pi 5 fit into the Pironman case?
Greetings Tino
Greetings Tino
It doesn’t fit, we’re releasing the Pironman 5 soon and this case is only compatible with the Pi 5.
thanks then I will wait
Greetings Tino
They swapped the positions of the RJ45 ethernet port and USB ports ![]()
I install a Raspberry 5 into my Pironman4 case and besides having to use the new scripts all seem to work. What would be different?
I installed the 5 into the Pironman 4 case and it seems to fit. What would be different?
Can’t wait thank you for making awesome products @SunFounder_Moderator
The new product is in the internal testing phase, and specific details may still be modified, so it’s not clear how much of a difference there will be in the final details, thank you for your attention.
I can’t wait either. ![]()
@SunFounder_Moderator i love the Pironman case for the pi 4 but i want to use a raspberry pi 5 ![]()
The exterior of the Pironman 5 has been changed from the Pironman. ![]()
When’s Pironman 5 coming out? @SunFounder_Moderator
It’s now in the internal testing phase, and it’s expected that real mass production will take until the end of March.
Please create higher quality boards. I’ve already gone through 3x pironman 4 boards since buying this.
Hi @SunFounder_Moderator
How long is the Pironman 5 going to be released in
Thanks
It should be next month.
Now I’ve waited so long and the discount code is no longer valid.
Greetings Tino
Please contact us via service@sunfounder.com
the discount code for the pironman 5 is pironman5-30%off
